Revolution
Revolution
How much for fork work and what do you get for this?
Reason I ask is Ive just had a quote from MH Racing as they are very local, and they've quoted approx £370 for ride in ride out respring and revalve, service and set up!
revolution is too far to ride up to from Swindon - thats the problem!!!
Paul
Paul
- Stormin Ben
£200 gets you:-
springs set to your weight,
oil to suit above,
reworking of standard woeful damping
return postage
and probably a couple of natty revolution stickers
It all depends if you are willing/ able to remove your forks and send them up to him or would prefer the ride-in ride out convenience at a premium
You could also phone Roger anyway and get his opinion of MH racing
He's so busy that he really doesnt mind putting work other peoples way so will give you an honest opinion if he thinks they are any good or will point you in the direction of someone he would recommend
oil to suit above,
return postage
But its not a very good one!
ZeroZero should be along soon, he had the ride in service done on his bike the time we all met up in the lakes a couple of years ago now, said it transformed his bike, i think he had the rear shock changed as well for around £800, i'd asume at least £500 was for the shock alone. and when he had trouble with the shock roger drove up to perth over a weekend and changed parts in the shock for him personally.
if you trawl back through Zero's posts you should find out the story and the correct cost.
cheerz
kev
kev
I just sooo couldnt resist that... I'm gonna pay for sure at a meet in the futureVTR1000KAZ wrote:I've used Roger before too... my current storm already had the penske shock on, but i need a bigger spring and a set up.
can't remember exactly how much it needed to lift.. but sure it was only around the ton mark.
it's yer own fault for making it so glaringly easy and I loves ya really
I'd say don't do it.
Taking suspension to bits and setting it up correctly is a black art of voodoo.
Unless you're strong with the gods, I'd leave it be, save up and get a reputable person to do it.
It's one of those things, I neve do brakes or tyres or strip things that are really complex (like fork internals) as fecking it up is expensive and life threatening.
Just my opinion though...
I'm quite handy at spanner twirling having rebuilt engines, a motorbike and built a kit car. I've also played with forks before so thats not an issue, however the last pair I did had fluid drain screws....doesn't look like these have!
I'll give anything a go. If I break it, well i'll just have to pay for it to be put right!
- sparrowlegs
- Contact:
You are right, the Storm fork legs don't have drain screws, unfortunatelybonerp wrote:I'm quite handy at spanner twirling having rebuilt engines, a motorbike and built a kit car. I've also played with forks before so thats not an issue, however the last pair I did had fluid drain screws....doesn't look like these have!
