Shock Spacer
Shock Spacer
Hi,
Seen these shock spacer things knocking about on www sites and ebay. Is it worth fitting one? Doesn't it make ur head shake?!?
Was thinking about a 3mm one. Just to tighten up my line. Once the forks have been rogered reckon it should be much improved with a spacer too?
Paul
Paul
- LotusSevenMan
- Stormin Ben
Karlos,
Try 5mm on the forks first.
10mm makes quite a difference and if its unstable already you dont wanna come a cropper
BTW what tyres are you using?
Andy
The benefit of using an n shaped spacer is that you dont have to drop the shock totally to fit it
All you do it loosen the top bolt, pull the bike towards you on the sidestand and slot it in
Its actually much easier than trying to get to the ride height adjuster on my Penske
Richard
Preload and shock spacer are 2 completely different animals
Changing the preload totally alters the way the shock works (its already way too stiff anyway -3 from min is the max preload I ever ran and that was only for track use)
The spacer alters the ride height without affecting the way the shock works (well for all intents and purposes anyway
Andy
Richard
But its not a very good one!
- Stormin Ben
Karlos,
Andy
Richard
Andy
Richard
- Stormin Ben
How'd I guess you'd be running Dunlops?
Found the reason they are so unstable compared to my prefered Pirelli's
The Dunslops use kevlar belts, the Pirellis (and most other tyres) use steel belts
Makes the Dunlops very grippy and forgiving in the corners but at the expense of straight line stability
WRT fairing, I still need my duck, sorry
However I may be persuaded to let the Blade fairing, screen & seat unit go
Let me know
Let me know
