Cooling Fan
genisis
Cooling Fan
Post by genisis »
Hi All,
Just picked up a 2001 VTR Firestorm (yellow)
what i have notied is the fan isn't working and when i tried to spin it by hand it is rubbing agaisnt the casing that it sits in.
Is it possible to remove the fan without taking the radiator and side panel off?
Thanks in advance.
Matthew
Stormin Ben
Post by Stormin Ben »
BEFORE you start messing around with the fan, please disconnect the battery
10 fingers is a nice round number & especially useful when counting in decimal base 10 :?
The usual cause for the fan sticking is a stone or road muck wedged between the fan & the housing
Run a finger round the inside and see if you can feel anything
Otherwise, I think you can loosen the rad and get enough clearance to access the fan without having to remove it totally
HTH
Ben
But its not a very good one!
storminateacup
Post by storminateacup »
Don't forget the fan only comes on when it is really hot (heavy traffic) so it may not be broke. My fan touches the side and makes a bit of a noise sometimes but doesn't stop it working.
genisis
Post by genisis »
I change the fuse the other day after reading some posts on here regarding the fan not working and i have had the bike hot enought to cause the fan to come on but nothing.
When i say it rubs it takes alot of effort to get the fan to spin.
I'm hoping to go away this weekend with it so will drop the fan off on thursday i did try and see if there was anything lodged in the fan but i havn't take the pannels off yet was hoping that i could avoid stripping the bike down :twisted:
Thanks for the advice :P
kevg
Post by kevg »
My fan comes on at 104 degrees and switches off at 100 i think it is...the 2002 has a digi thermometer. 8)
cheerz
kev
genisis
Post by genisis »
On a side note :lol:
i picked the bike up last week .
it a 2002 registration on a 2001 plate but when i was looking inside i notice a model code of FY which i think is the 2000 model.
is there any other way for me to find out the model of bike.
i have the old style clocks so i'm guessing i also have the smaller tank and lower bars etc :P
Bike was a bargin though so doesn't really matter that much :wink:
cheers
matthew
