clucth noise
patty
clucth noise
Post by patty »
hi all,
just wondering weather a new set of clucth friction plates would solve the clucth noise i get when my storm is ticking over??
once i pull the clucth lever in all is quiet ,but as soon as i release it the noise is there.(i know ive had clucth noise on other bikes,and its the norm...is it the same for the storm??)
gear changes seem fine ,no slipping etc.
i take it i would need new springs aswell??if plates were needed.
which plates (if thats what i need?)do you lot recommend?
as there is some vance and hines ones on ebay for £30 ,( i like there exhausts)dont know about there cluctch plates though.
also might have a chance at some barnett ones ,but these are £50.
dont know how much honda ones are??
as for ebc kits ,ive suffered good and bad ones ,so i think i will leave them this time.
any info would go down nicely.
cheers you lot :)
pat.
yellow all the way...
who needs 4 cylinders when 2 are this good!!
storm no more...rsv power now.
(along with 85cc of honda finest)
VTRbob
Post by VTRbob »
mine does it m8, sounds like a diesel till i pull clutch in :lol:
clayderman
Post by clayderman »
Are you sure it's not just the friction of the gearbox slowing the engine down causing the engine to sound like a clutch rattle? then when you pull in the clutch lever it takes the extra drag away and the engine ticks over better. Just a thought, maybe tickle the idle up a fraction and see what happens :)
Dazjm
Post by Dazjm »
Mine does the same as it idles :?
Is this detrimental to the clutch, or just one of the bugbears?
They all do.
Unless it's really bad I would leave it. Guaranteed if you sort it it will only be back again in a few thousand miles. As long as it works fine don't worry.
VeetyR
Post by VeetyR »
yeah mine does this too.....infact most big hondas do it blades, viffers etc.....defo nowt to worry about unless it sounds like a spanner going round inside it.
As for replacement plates.....when i replaced mine on my last bike i used wemoto.com for the plates(made by Kyoto)....then i got the steel inbetweenies from a honda dealer( didnt know i needed em when i ordered from wemoto lol ) VeetyR
Keep it gutter...Keep it grimey..........one!
patty
Post by patty »
think i will stop worrying so much then.
cheers u lot :!:
KarlosVTR
Post by KarlosVTR »
noisey thrust bearing mate.nowt serious.if you want a replacement go to a bearing supplier - not honda for wombles sakes and ask for a 8003 in their best quality bearing available
patty
Post by patty »
karlos,
is this a easy/hard job to do???
cheers
pat.
