sprocket cover removal........
VeetyR
Post by VeetyR »
Guys, have been trawling thru some posts on clutch noises and have found members have had similar "graunchy" clutch issues.
I am about to try a couple of the remedies suggested and these seem to be simple enough exept for one thing that is bothering me.
I want to take the front sprocket cover off and clean the "plunger" for the clutch. I did notice however that the clutch slave is actually bolted onto and through the sprocket cover into the engine. So my Q to you is......
Can i Remove the cover and slave as one or do i need to remove the slave first and replace the gasket between it and the cover?
What is the best procedure to use? anything i should be wary of? and has anyone done this before??
Thx John'o
Keep it gutter...Keep it grimey..........one!
genisis
Post by genisis »
Hi,
I'm not sure if you can remove the cover with the clutch cylinder still in place however if your careful when you remove the cylinder you shouldn't need to replace the gasket i have removed mine a couple of times to try and fix a leaking seal.
i also fitted new clutch spring to try and remove the noise Some EBC heavy duty spring but it didn't make any difference.
Hope thats of some help
Matthew
kevg
Post by kevg »
i think you can remove them both together, i don't think all the bolts go through to the engine block, some of them are taped into the sprocket cover.
if not the spring and piston assembly isn't that strong that it will fly out in all directions if you are carefull, it will slowly push out.
cheerz
kev
Squiffythewombat
Post by Squiffythewombat »
I actually did this last weekend! You can take both off together but it is much easier to remove the slave first. Beware the gasket though, its really easy to tear!
Thread Hijack - Anybody know where i can get a new gasket or shall i just make one from a cornflakes packet again?
Squiffy_The_Wombat
LotusSevenMan
Post by LotusSevenMan »
Squiffythewombat wrote:thread Hijack - Anybody know where i can get a new gasket or shall i just make one from a cornflakes packet again?
Cornflake packet? Oh c'mon.
Use a Kellogs Special 'K' box. It's much lighter :roll:
Wildfire
Post by Wildfire »
:lol: :lol: :lol:
Thread Re-Hijacked.....LSM...Any chance of the HTML/ Code / Link whatever it is for your Signature dancing VTR?...For another forum I'm on
Squiffythewombat
<i c=" h t t p : / / i m g 4 8 3 . i m a g e s h a c k . u s / i m g 4 8 3 / 8 5 6 7 / d an c e v h d 2 . g i f ">
Wildfire...remove the spaces and enter in this code. Any time you want to display an image you need to use the XHTML tags. Its simple, its works like this:
use an opening bracket "<"
Then type "img"
Then a space and "src="
Then copy and paste the images link (with speach marks!!)
Then close the statment using the opposite bracket ">"
Squiffy_The_Wombat
Squiffythewombat
arg stupid forum, it wont let me display the code properlly...PM me your email address and ill send it over for you!
LSM - special K is mine kind of K! :D
(cornflake packet gaskets have saved my bike many times before, not sure if i trust special k!)
Squiffy_The_Wombat
'Frosties' would be wiser with the colder weather around the corner :lol: :lol: :lol:
I'll get my coat :wink:
Squiffythewombat
either way its going to be tesco value im afraid lads...student now ya c! ;-)
Squiffy_The_Wombat
cupasoop
Post by cupasoop »
Squiffythewombat wrote:arg stupid forum, it wont let me display the code properlly
That's because we dont use xhtml tags here, only Image
http://img483.imageshack.us/img483/8567/dancevhd2.gif[/img]
Take the spaces out of the first [img]
Rich.
Wildfire
Post by Wildfire »
Like this I presume :D
Thanks
Squiffythewombat
LOL! :oops: :oops: :oops: :oops: :oops:
I keep forgetting this version of BB doesnt support that! Werid tho as i thought you should be able to use the HTML tags too, evidently not!
Squiffy_The_Wombat
Stratman
Post by Stratman »
New clutch slave gasket £2.30
Cornflakes £2.80
1/2lb bacon and a loaf of bread £2.00
What is my point? I have no idea.
VeetyR
Post by VeetyR »
Stratman wrote:New clutch slave gasket £2.30
Cornflakes £2.80
Neither do i strat but 1/2lb of bacon and a loaf a bread sounds very good at this time of the morning( 08:57 ) :lol:
