shorter rear indicators
hi, im sorry if this has been covered many times before but can someone tell me where i can find some shorter road legal rear indicators that are a direct replacement as the standard ones stick out a mile !
Remove indicators, remove long stalk from indicators, screw the now dumpy indicator back on. You'll need a repair washer as the hole the old bolt went through is much wider than any screw you'll find.
ps, remove cdi as well from under the seat. It makes removing and refitting the indicator wires so much easier.
Rich.
I've just fitted clear led light like Firestorm mike, powerbronze £75.00 and it has built in indicators and plate light! took it to my garage where MOT's done and he said no prob for test even looked in VOSA book which stated but don't quote bike must have indicators and be on a horizontal plane.
I know some garages said when I was looking at these that there is also a minimum distance they must be apart, but my garage didn't mention this when he was reading out the details
