Any Piccys of indicator alternatives
As the title suggests. has anyone got any Piccys of indicator alternatives (front and rear). I would like some ideas before splashing out on a piece of useless tat! Im a snob and know what I like but I have not seen any VTRs with close up pictures of indicators. I have seen fireblades with flush fitting car type side repeaters and they looked v good. Thanks in advance for any response.
jp who owned the bike before me fitted em.....rear is same, under seat unit.....cos bike had high levels fitted, now ive gone back to low levels, ive fitted some micro indi's into the undertray...a warning tho, the flush mounts arnt mot legal at the rear'''they are at front for some reason
as for fitting, same as normal ones...
- clayderman
Yes , yes, yes this is what I am talking about.......choices, choices. All are a damn sight better than stock. Like the idea of not fitting LED (relay faff). Clayderman your rears look V neat any grief fitting?
- clayderman
No probs at all, just one hole through each side of the undertray and put some bullet connectors onto the indicator side of the original loom. I originally bought some motrax led ones for 25 quid then when they flashed fast I thought I would buy one of their flasher relays until I saw the price n thought sod that, saw those ones for 15 quid n I liked them more. I did also think about an integrated led rear light but I liked the fact of having the indicators spaced slightly further out from centre.
Yep I still want to be seen, no point in giving some inept drivers the excuse for taking me out.clayderman wrote:No probs at all, just one hole through each side of the undertray and put some bullet connectors onto the indicator side of the original loom. I originally bought some motrax led ones for 25 quid then when they flashed fast I thought I would buy one of their flasher relays until I saw the price n thought sod that, saw those ones for 15 quid n I liked them more. I did also think about an integrated led rear light but I liked the fact of having the indicators spaced slightly further out from centre.
- Stormin Ben
Fronts
M&P finest cheapies. Worth taking your time when fitting to make them fit flush with the curve of the fairing.
Then they work beautifully in conjunction with the crash bungs to keep the fairing off the road
Rears are TBH a bit w4nky
They fitted the bill at the time -I bought the high levels and had to replace the OEM wobblers (look tidy enough, cost peanuts) but are not bright enough
But its not a very good one!
