Bike wont start / Rapid clicking from rear
had a similar problem on my last bike( tl1000s).....it was the starter relay....take the connectors off...gave em a good clean..refitted and a good spray wi wd40..and bingo no more problems, was exacttly as yours...try wiggling the starter realy harness as u thumb the starter, if it fires or trys to ..theres ur culprit, worked for me
- Pete.L
Dazjm said
Another thing you could try is removing the spark plugs (which will remove the load on the starter moter and see if it will turn over then. If it does I would definitly look at the starter mechanics.
If they work out of the bike and not in the bike using all your original wiring I would sugest you look at the clutch mechanism which engages the starter motor to the engine. If it is seizing intermittantly or siezed it may be stalling the starter moter.Went round bob the builders gaff tday.
Took his starter off his bike (after much wrestling with the bolt) with the intention of testing out the 2 i have, as well as the starter solenoid.
Both my starters worked , as did the starter solenoid!
If they both worked spot on at Bob's then I can't see why they didn't work when you tried them with the jump leads, with the s/motor not fitted to the bike. Are you sure you had the jump leads connected the right way around to the starter motorDazjm wrote:Yea, i basically had the starter sitting on the deck, with the cable disconnected. Connected up jump lead from neg on battery to motor case, and connected the other lead to the posi term on batt, and touched the bolt on the front of the starter.. i got an almighty spark, with some bolt meltage. The batt was d/c from the bike completly. Imo the motor should have started up, but i dunno. Took em to Bobs and they both work wombles spot on.........When you tried the starter motor with the jump leads (as above) after removing it from the bike, did you remove the heavy cable going to it
Its honestly driving me up the wall. There must be something in the fact that it started the motor when i bounced about on the bike. Like a loose / corroded connection somewhere, somethin to that effect. Its intermittent, but moreso on the side of not workin.
I'd try a different battery using the jump leads to the starter motor while it's not fitted to the bike
- Pete.L
Ah! I missed this bit
That sounds like shorted windings. It could be cause by muck across the stater or a winding itself braking down. Did it do it on both moters? You could try rotating the moter by hand and powering it at different positions. You might find that you have some dead spots where it doesn't move and other places where it turns as normal.Yea, i basically had the starter sitting on the deck, with the cable disconnected. Connected up jump lead from neg on battery to motor case, and connected the other lead to the posi term on batt, and touched the bolt on the front of the starter.. i got an almighty spark, with some bolt meltage. The batt was d/c from the bike completly. Imo the motor should have started up, but i dunno. Took em to Bobs and they both work wombles spot on.........
Dont wanna tempt fate, but i think i got it fixed
Was confused at how my bits worked on bobs bike, was convinced i musta had a dodgy connection somewhere, especially if jumping up and down was starting it, so i traced the cable coming from the neg terminal on battery to the starter sensor, where its bolted onto the frame....
From my recent trouble with the speed sensor, i had obvioulsy left the bolt finger tight.. so it was slightly loose.
Im hoping on tightening this connection, that the fault was i wasnt getting a good earth connection, hence making the load for the starter solenoid even bigger.
We can only wait and see.. But it started 1st time after sitting outside for a few days
Thanks everyone for the help. This forum is a godsend.
And thank god bob lives across a field from me.
- storminateacup
Yea, no sh1t.
Took a scoot over to Bobs, show him what all the fuss was about.
Well as i was leaving and about to turn sharp right out of his drive down a hill, did i not just stall the mofo, and drop it!! noooo...
First drop, well it was more of a controlled put down, no real damage thankfully, but what a sh1t end to an otherwise sh1t week
On an even shitter note, both me and bob reckon my bikes needs the front CCT changed, as its rattly.
WOOP TE DOO........ so expect more frantic posting about jumping cam chains, bent valves and the like!!!
wish me luck
wish me luck
Daz, I got Hazel to sweep up the loose chips from the drive where you had your wee trip today( well,she wasn't going to help me roughcast anyway!) so it's a wee bit safer now.
Jokin' apart bring up the bike if you want a hand to replace CCT's and leave it here whilst completing the job, told me mate tonight to get the Norton back to his own gaff so more room now available.
