I'll ignore the first bit Chris (LSM)LotusSevenMan wrote:Can't you just use your wifes nail polish like you normally do (ooops. Sorry. Forgot I said I'd keep quiet on the subject. Don't worry. No-one will know!!!)![]()
There are some good spray ones used for model aircraft so are fuel proof. They do change the colour very slightly but don't go flaky or yellow off like some laquers.
Thanks for the info Warby, a very good pointwarby221 wrote:If your going to use a fuel proofer for use on model aircraft make sure you get the right one most model aircraft engines run on nitro methanol and it has different properties to petrol as nitro acts like a paint striper “nitromors” so ask for fuel proffer for petrol engine use you’ll find that its only epoxy clear coat so probably cheaper at a motor paint factors
