Engine Lacquer
Engine Lacquer
Has anyone used a good clear engine lacquer that they can recommend :?:
LotusSevenMan
Post by LotusSevenMan »
Can't you just use your wifes nail polish like you normally do (ooops. Sorry. Forgot I said I'd keep quiet on the subject. Don't worry. No-one will know!!!) :D
There are some good spray ones used for model aircraft so are fuel proof. They do change the colour very slightly but don't go flaky or yellow off like some laquers.
LotusSevenMan wrote:Can't you just use your wifes nail polish like you normally do (ooops. Sorry. Forgot I said I'd keep quiet on the subject. Don't worry. No-one will know!!!) :D
I'll ignore the first bit Chris (LSM) :lol: :lol:
I hadn't thought about ones for model aircraft, thanks for the tip :D
warby221
Post by warby221 »
If your going to use a fuel proofer for use on model aircraft make sure you get the right one most model aircraft engines run on nitro methanol and it has different properties to petrol as nitro acts like a paint striper “nitromors” so ask for fuel proffer for petrol engine use you’ll find that its only epoxy clear coat so probably cheaper at a motor paint factors
warby221 wrote:If your going to use a fuel proofer for use on model aircraft make sure you get the right one most model aircraft engines run on nitro methanol and it has different properties to petrol as nitro acts like a paint striper “nitromors” so ask for fuel proffer for petrol engine use you’ll find that its only epoxy clear coat so probably cheaper at a motor paint factors
Thanks for the info Warby, a very good point :!:
PS. Kaz I guess you've sobered up now :wink: :lol:
Squiffythewombat
Post by Squiffythewombat »
Interesting idea chris, but which products? some are much better than others?
Squiffy_The_Wombat
LotusSevenMan
I have used ones by 'Flair' and also the good old Humbrol one that was but probably is no more (who owns/does that stuff now).
There are these spray cans like this too.
http://www.hobbiesr.com/top/top-137/topr7501.htm
Cheers Chris (LSM) that's very helpful :D
