OK, what would casue this symptom?
Idle speed wont hold at a constant revs and it hunts furiously over 1000 rev range.
Everything else is absolutely fine running wise.
Roger's gonna fix it, but I'd like to get an idea what might be causing it.
Idle ideas
Idle ideas
I agree too, it could be due to an air leak somewhere, but it could be due to quite a few different posibilities imo.
(1) Carbs need balancing.
(2) Idle jets need adjusting, mixture wrong on tick over.
(3) Spark plugs need replacing or regaping.
Thats just a few of the cheaper options before you start going into the more expensive posibilities.
I'll be interested too hear Kitch what Roger finds that is actually the culprit.
