GFK Belly Pan?
GFK Belly Pan?
Did we ever get any feedback relating to the cheap German belly pan fitment (GKK at £35)? Has anyone had one delivered and actually fitted it? I am aware of one member that took one look and threw it away but are they really that bad?
Thanks buddy, its that thread I am hoping to boost along a bit, £35 seems like it may be worth the grief of making a bracket and spray to suit.Timbo wrote:http://www.vtr1000.org/phpBB2/viewtopic.php?t=10549
It seems one made it to the shed floor, but no word from Andy1671, the original poster.
gfk belly pan
Hi fellas
sorry not to have followed up recently but not quite finished yet .Up to now i have managed three mounting points the first picks up on the original mount on the right side of the bike the second has a bracket made of 4mm plate ally cut to 20mm wide and bent in an arc to fit to the front original mount the third again has a bracket made from the same plate this is in a U shape and is about 30mm long with 20mm ends(if that makes sense) this picks up on a screw from the sump i have used captive m6 nuts( that i found at work) it seems quite stable with just three but i will have to see when it is painted and back on the road.On the subject of paint would any body know the paint code for the BLUE storm i cant find it anywhere on the machine
Hope this helps i will try to put pictures up but i am not a computer wizz so i am not promising
Timbo i am only down the road from you in skem so if you wanted to see it when it is finished i will pop up and show you
Andy
Andy
I have reverse paranoia I think i am following somebody
- clayderman
what colour blue is it? is it like this?
http://i28.photobucket.com/albums/c236/ ... Medium.jpg
if it is, the paint code off the top of my head is PB215C
- clayderman
Try this listing on here
http://www.cyclecolor.com/id25.htm
paint
No i could not see the code but it is the same colour as the bike on page 15 of the gallery marked as mik-str
Andy
Timbo i am just down the stannanought rd in ashurst
Andy
paint
paint
See timbo i said i was not a computer wizz
The colour is lapis blue according to a picture in the gallery on the first page you get when you log in
Will sort a ride out soon when i get the tax back on it
Andy
Andy
- sparrowlegs
- Contact:
- sparrowlegs
- Contact:
