Mega Bargains at Lidl!
goffy
Post by goffy »
Just been to Lidl, came out with two really good deals,
30% more light zenon headlight bulbs £3.99/pair including 4 other bulbs!
Choose your flavour H1 H4 or H7 all the same price.
(pretty sure the VTR takes H4)
Inexpensive upgrade, fairly sure you won't get even standard H4s that cheap, H1/7s tend to be very much more expensive.
I've laid in a stock!
Also doing semi automatic compact battery chargers at £9.99.
These are 3.6Amp 14.4Volt switch mode jobs, not as sophisticated as the Accumate or Optimate (don't have a desulphate function and you have to select bike or car mode) but 1/4 the price.
The other functions are fully auto, deep discharge(pulse)/bulk/trickle. just connect and forget!
Use one of thes between rides and you won't need a £40 Opt/accumate.
Seems very well made and is IP65 weatherproof too.
LotusSevenMan
Post by LotusSevenMan »
I have used that charger from a deal a while back for about two years now and can't fault it!!!
See:-
http://www.lidl.co.uk/uk/home.nsf/pages ... .index.ar1
Also coming up:-
