See the article here
Called a road stud........................................................... and I thought that was me
http://www.telegraph.co.uk/news/main.jh ... peed07.xml
New type 'Cat Eye' speed camera on test!
- LotusSevenMan
Many moons ago when I started riding the thing to do was to put a mud flap hung from bottom of your number plate using a hinge then put a spring down the side of it when the bikes moving the mud flap gets sucked up by vacuum created behind the number plate by adjusting the size and position of the spring and the weight of the mud flap you could change at what speed the mud flap flipped up
Obviously I never used this idea but in told it worked on a very wick h2
Not sure if it would still work on the more slippery machines of today
