Adhesive remover
Beebug52
Adhesive remover
Post by Beebug52 »
Hi
Does anyone know what I can use on the fuel tank to remove old adhesive?
I bought a secondhand tank and it had a tank protector on it but was lifting off - I removed it but has now left with a ghost imprint
Thanks
Buggy
LotusSevenMan
Post by LotusSevenMan »
Are you sure that 'ghost imprint' isn't just the tank colour fading on all the rest of it? Normally red colours are worst for this. Only way around it is normally to fit a new tank protector that does stick correctly!
Beebug52
Post by Beebug52 »
Tried WD40 doesn't seem to do much :?
Defo old adhesive imprint and not fading - will prob stick another over the top:D
Am going to repaint at some stage but need to save a few pennies before I do that :oops:
.............Thanks
Try white spirit
cupasoop
Post by cupasoop »
Lighter fluid
Rich.
chuxsta
Post by chuxsta »
white spirit as mentioned should do the trick.. dont want any thing to strong cause it might dmg the laquer on the tank... let some whitespirits soak into it before rubbing like stalker in the bushes at the changing room window..
if its thick adhesive it will take time for the white spirit to break it down.
Andy1671
adhesive removal
Post by Andy1671 »
Try I P A isopropanol alcohol have it in work and it shifts anything not sure where you would get it from though
I have reverse paranoia I think i am following somebody
Beebug52
Post by Beebug52 »
Thanks for the tips everyone - much appreciated :D
Re: adhesive removal
Chemist should have it, though they'll give you a funny look
For good measure also ask for a bottle of codeine cough medicine (not shaken ;) )
Otherwise CD cleaning fluid is the same stuff - isopropanol alcohol not cough med
Andy1671 wrote:Try I P A isopropanol alcohol have it in work and it shifts anything not sure where you would get it from though
Zakalwe
Post by Zakalwe »
Paraffin is my new bestest friend. I use it for general cleaning and de-greasing, but it also does a great job on removing adhesive off a tank.
chuxsta
Post by chuxsta »
well i just spent nearly 2 hours removing the gay yellow wheel stickers off my front wheel, ( yeah i still got the rear wheel to do )
and after using a hair dryer to remove the tape there was a lot of gunk left over from the sticcky sh1t and a good degreasent did the job after it was left to soak in...
and on that note... before you apply wheel trim stickers please make sure its for life... cause although it takes a few mins to apply it takes some poor SOD ( me ) hours to remove!!!
