Drip from carb
topper
Drip from carb
Post by topper »
Hiya, need some adivce, am getting petrol dripping from my rear carb. Its not pouring out but the base of the carb is wet also her indoors is moaning about the smell in the garage :cry: Cheers
Andy1671
Drip
Post by Andy1671 »
Hi dont want to sound obvious but i had a similar fault on my Ducati it was just the drain screw that had worked its self loose or possibly a sticking float making it overflow
HTH
Andy
I have reverse paranoia I think i am following somebody
RedStormV
Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
Post by RedStormV »
Hi mate,
Can you see where the leak is coming from? supply pipe, float bowl gasket etc?
If not then tank and air box removal are straight forward enough - just mark which pipes you remove from where. Draw a little pic of tank underside if it helps and number end of pipes with a biro or tipex pen.
This will give you better access to see carb and wipe off fuel to see if you can work out where it's coming from without disturbing them.
Avoid carb removal if you can, only to save probably having to balance them if you do.
Check all pipes on the carb including drain pipes to make sure they're all a snug fit.
Possibly float is sticking so carb is over filling.
Has anything been changed or done to bike / carbs recently that may have dislodged anything?
Stormin Ben
Post by Stormin Ben »
Does it still drip if you turn the petrol off under the tank?
Could be a split diaphram in the fuel tap
Ben
PS remember to turn the tap back on again when you re-assemble
PPS yes I have learnt the hard way :oops:
But its not a very good one!
topper
Post by topper »
Thanks for the advise guys :lol: Have tank & airbox off, wiped any fuel away, then saw petrol was weeping threw float bowl gasket :cry: Ok confession, have removed both carbs while still joined together (didnt want to take split carbs, throt cabe & sensor etc). Removed bowl and rubber gasket has been pinched, from new by the looks of it. Now just have to wait till Tues/Wednesday for part, if im lucky apparently :x
Will let you know how it goes later this week
RedStormV
Post by RedStormV »
Well done mate.
At least you seem to have found the problem and one that's easily sorted.
Good to hear you kept the carbs together.
You might get away without re-balancing too if you're lucky.
That's what we're here for afterall, have a laugh and help each other along the way or 'a meringue'?
topper
Post by topper »
Hiya, All sorted with new gasget, carbs back on together, started straght away but didnt run well :cry: some numpty didnt put the pipes back on the tank correctly :oops: All running nicely now :wink: and no smell of petrol :lol: and to make things better the sun is shining :D
