do the run of the mill long stemmed indicators fit ok on the front of the storm using the same mount points as the oe ones.?
i know if i took the stock ones out n measured i would know but sat at work its kinda hard to do...
yet another indicator question
as far as im led to believe, i could be wrong, with the LED winker speed its just a case of putting the correct size resistor in the connnection.bigrich wrote:I just added some arrow led indicators from busters got them for 15 quid and fit fine with standard fixings.
Also fitted a led rear light with built in indicators and needed to get a new relay to slow the rate down, pish easy to fit but added another 20 quid to the bill
seen a guy selling home made ones on ebay for £5 each, per winker.
just need to find out what size resistor is needed.
to make them your self we are talking pence...maybe a whole pound for all 4.
yup they sure do but you can encase them in various things to prevent any damage from the heat...bigrich wrote:resistors get mega hot and you can not put them on or near plastic or paint. the motrax resistor is hust so easy.
i would buy a marketed item if they wasnt so over priced for what it actually does...
slowing the rate a set of lights flash, for £20+ is messed up imo.
