new member with a problem
ginganuts
Post by ginganuts »
hi all im a new member my names dan
i have a problem with the storm. i had it in the garage from sept till just a month ago. so i charged the battery fixed it back on then away i went back home. just a few yards from there it died, no electric at all, turned out it was a 30amp fuse. so the next mornin go to pull away and then it blows again. this has happened 3 times and now the dash doesnt even want to light up :(
it does have a meta alarm and the battery is still fine
can anyone help please its drivin me nuts
thanx
Hankie
Post by Hankie »
If it's blown a new 30amp fuse then it's likely to be a short. Check no cables are trapped anywhere and look for damaged insulation at points where wires bend over the frame etc. Was it raining when this happened? (bike very wet). With the ignition off you could also connect a multimeter set to amps between +ive terminal on battery and +ive lead to measure current draw. Should not be more than 100-200 mAmp for the alarm (can't remember what the rating of mine is...). Disconnecting the alarm for this test would be good (but not simple). After that, you get into testing live (ignition/charging) and lighting circuits which gets more complex. Hopefully the cause is easy to spot.
I hate electrical problems, diagnosis can be tricky, take it to a dealer and you're paying for labour and they could tell you anything. Take it somewhere you can trust if you must take it to a LBS.
Chris
jonesy
Post by jonesy »
Hi Dan, this might be a long shot, but i should check your regulator/rectifier, as the symptoms you describe are the same that i had the first time mine went!!! that was an original gel reg/rec, before the better finned ones.
Not all those who wander are lost...
pariah
Post by pariah »
Hi giga.
I agree, get the rect/reg replaced.
Mine kinda went funny, not starting and the speedo went dapy on me. Wished I had know what and how much it was gonna cost me. New reg/rec plus Battery as it got cooked. 148 squid and lost 3 days work as was stuck over otherside of country.
:cry:
Stratman
Post by Stratman »
I'd check the regulator too. It will fail at some point and to replace is easy. I got a finned one (can't remember who from, but google bike rectifiers and you will find them I think they were Electrex or something)
You can soon check it with a multimeter - there is a sticky on here somewhere with all the procedures and I followed it OK. I had never used a MM before!
ginganuts
Post by ginganuts »
thanx everyone. think im gonna have to get a meter then.
dont suppose there is anyone near harlow area that fancies helping out :wink:
is my sig toooo big :lol:
LotusSevenMan
Post by LotusSevenMan »
Ginganuts
See http://vtr1000f.wickidnet.com/
I guess your forum name is due to you riding your bike before the tank paintwork was dry eh?
