Kitch wrote:I just replaced my Avon Storm ST's... after 10,000 miles and they were down to the wear bars.
Fitted Michelin Pilot Road 2's and I'm very very impressed with them so far. Estimating 6,000 - 8,000 miles from them.
How come you're changing to the Michelins ?
I've always gone for Bridgestones, but mates got the Storm st's on his gsx14 and he flings it all over the place, I'm thinking of replacing the 021's with these. The Bridgestones are wearing quite quick in the middle now after 4000 miles. Maybe get another 1.5-2k out of them
Bloody hell! I must be ham fisted! As the guys will testify lookslike I will get about 2-2.5K out of my rear 021 Still better than 1200miles out of the 014's
Pilot sports on mine,rear less than 2000 miles and squared off with no visible tread pattern in middle.
Bit pissed off about it,cos still quite a bit of meat on front,so will have to buy another rear,as its not advisable to mix n match ,.....is it
Use a safe type of stand like this for front and rear wheel removals myself. Those bricks/slabs etc look scary.
That is a genuine issue scissor jack to support the engine by the way/front of bike as you need it.
Pivot point is the swing arm pivot. Both wheels are clear of the ground here by the way.
Just gone the 021 route myself. Had 020 before.
LotusSevenMan wrote:Use a safe type of stand like this for front and rear wheel removals myself. Those bricks/slabs etc look scary.
I made these thingys to lift my Triumph ,a pin went through where the centre stand had been removed,with a flat plate supporting the sump,it worked a treat Still got the trolley jack lift.
