WHat are people's feelings on renthal sprockets, are they worth paying extra for?
They do an 'ultralight' front and a hardwearing 'hard anodised' rear but I'd be paying £54 delivered for the pair?
Would you guys and girls recommend that I go for steel on a storm and get JT sprockets instead?
Chris
Renthal Sprockets worth the extra?
1997 CB250F Hornet Japanese Import
Twin Yamamoto Carbon Exhausts /
Hagon Shock / Coerce 250 Bellypan
Black Anodised Span Adjustable Levers
Uses the Firestorm front brake caliper so that counts...right?
When I had Hornet I wore set of Rentals aluminium sprockets in less than 10 000 km. That was end of my experience with "lightweight" Rentals. As long as standard sprockets size is OK I always going for Honda ones and never ever regretted it. Specially since Honda front sprocket come with rubber/plastic guide that gives a bit extra mileage to chain and sprocket.
In here set of Honda sprockets would cost same as JT, so no point unless change in teeth needed.
4 wheels moving body, 2 wheels moving soul
