Drilled baffles....poor mans race can !
bikerpiker
Post by bikerpiker »
Very nice :twisted: ...a fair wee bit of work has went into em !
Nice pic Chris (LSM) a good shot :!:
If you look at it quick it looks a bit like you've shoved a shuttlecock in the end of the can :lol: :lol:
LotusSevenMan
Post by LotusSevenMan »
I have Sirch.
That IS a special lightweight shuttlecock baffle. Well spotted :lol:
bikerpiker
Battered baffle
Have now done what a few people have done on here and elsewhere.
As posted previously,i had drilled 8 holes round my baffles,which,i drilled bigger n bigger untill i couldnt get a drill in :!:
Today i got a small sharp chisel,and cut from hole to hole,then gave each baffle end an allmighty clout with a copper mallet,well a few actually,and oot it came :!: :twisted:
Tried to clean up round the hole with my wee battery dremell but it ran out of puff,so started using a round file....then i ran oot of puff :lol:
Will try a rottary file or similar,or borrow an elecric dremell.
The sound is excellent,,well for a standard can anyway :!:
I really should have looked into it more,hope i dont need to re-jet or anything.
Desparate to try it,but it's just started pissin doon :!:
(cant complain,had no rain but odd, n i mean odd shower for aboot 6 weeks) :!:
pariah
Post by pariah »
Hey biker, why didnt yh use one of them there large hole saws that yh fit to the lece drill. they come in different sizes. there often used to cut holes for large waste pipes to go through
Would have been so much quicker .
Just a thought.
bikerpiker
Didnt have one correct size mate :!:
Also with me drilling 8 holes,which,in the end were about 12 mm dia,there wasn't much steel in between.
Only took a few mins each side to cut with small sharp chisel going from hole to hole :!:
pariah
Post by pariah »
maybe i,m thick here, but surley if yh remove all the guts. wont that affect the correct back pressure for the engine . :?: Why do i know that chukky is gonna come back wid some thing to do wid toilets here. :lol:
Zakalwe
Post by Zakalwe »
Drilling baffles...the ultimate ghetto modImage
I did it on my old 'Storm.....made it sound like it should have sounded like!Image. Have also done it on the Fireblade (2 x 30mm hole saws down the exhaust pipe).....nice and rumbly low down with a nice tone without being offensive. Youtube video...this is not my bike though
bikerpiker
Not removing all the guts mate,just the end baffle,when i look in the hole im sure there is another 2 which are not accessable unless the can was cut open :!:
stevie
bikerpiker
Here's a 'storm with the drilled baffles,if you look close you can see the holes.
pariah
Post by pariah »
can yh get a pic of what yhs done for me, Might consider doing the same .
Zakalwe
Post by Zakalwe »
pariah wrote:can yh get a pic of what yhs done for me, Might consider doing the same .
Have a look here. This describes a full bafflectomy, where all of the baffle is removed.
What I did on my old 'Storm was drill the connecting plate between the exhaust "snorkel" and the outer. You can even get a big "washer" made up that you could fix in place with a self-tapping screw to return it to stock (MOT time)
pariah
Post by pariah »
Fool proof that zac. not to sure about wanting to remove all of it though.
bikerpiker
Yep,thats what i did, i didnt need to go in with a screwdriver though.
Once the baffle was clouted in, a few wiggles and it pulled out no problem.
Now i just need to go on to ebay n buy a couple of micron exhaust stickers or similar :wink:
bikerpiker
pariah wrote:Fool proof that zac. not to sure about wanting to remove all of it though.
Try the drilled holes mod 1st,then if youre happy,drill em out bigger :!:
