fuel tap vacuum
shaun1978
fuel tap vacuum
Post by shaun1978 »
Right ive got a small problem here chaps, just replaced the engine back into the frame , and its all ready to go apart from the vacuum pipe that goes to the tank...... I cant remember where it goes... it's connected at the tank end and theres two other ends.... anyone able to help?
RedStormV
Location: West Yorks (Bronte Country) - Home of the Negro Lesbian Cornet Players
Post by RedStormV »
The vacuum hose comes from the rear intake. It goes to the fuel tap to ensure that the fuel tap only passes fuel when the engine is turning over, creating vacuum.
HTH
shaun1978
Post by shaun1978 »
Right I've had a look today and I'm still not sure where your on about.
Is there any chance someone could post a pic up?
warby221
Post by warby221 »
Looks like its time to get yer Fitches out again there red :wink:
He just loves showing of his fitches :P :P :P :P
Stratman
Post by Stratman »
Bit confusing as you say the pipe (singular) has two other ends?
The vacuum pipe attaches to the petcock assembly at the small side pipe, not the bottom. There are two other pipes that go on the petcock, one for each carburettor fuel inlet. You then have a short overflow pipe and the breather from the tank itself.
RedStormV
Post by RedStormV »
Not sure how much if any these will help but here goes anyway.
Possibly of more use is ...
This shows picture of the connection...
Failing that, it's a trip outside with some tools and have a look see and report back for one of us matey.
I'm sure there's a thread with a good explanation but I'm damned if I can find it. :oops:
Beast
Post by Beast »
Vacuum pipe should be singular... goes onto the inside of the rear cylinder head doesnt it not? :)
Yep
Rear cylinder diagram 12.3b above shows a view from the left hand side of the bike (when sitting on it) just at the base of the carb inlet.
