handle bar risers
balls
handle bar risers
Post by balls »
do they make much difference ? :D :D
bikerpiker
Post by bikerpiker »
Tricky question :!:
Everyone is different weights,different aches n pains ,so different needs :lol:
The Genmar and GB moto 19mm risers do make a difference for sure,but,for some people,me included,it wasnt enough :!: I fitted the bolt on to the yoke type which are readily available.
Raise your bars 19mm up the forks ,and tighten (obviously) :lol:
Run like that for a few days or weeks,if that height suits you,buy gb moto or genmar,if you need more height you would need to buy bolt on risers and change the bars .
pariah
Post by pariah »
VFR Bars, cheaper and fit straight on. Small mod to upper fairing for switches. Made shed loads of difference for me.
bikerpiker
Mmm, dunno aboot that :?: ..depends what you can pick up a pair o vfr bars for i suppose.
I got my renthal type bars and risers for around £45ish if i remember right :? I too had to trim my fairing a bit.
Vtrbob done the modification using risers that bolt on,renthal type bars ,with no fairing cutting , maybe that's the way to go :!:
Anyway after doin 100miles or so,im still sore back,butt,etc,,friggin Goldwing i need :lol:
