speedo
firestormcrazy
speedo
Post by firestormcrazy »
help!!! i ve ran out of ideas and need some advice. When the speedo reads 30mph im only doing 25 and its doing my nut in. I have changed the speedo drive and the clocks and checked all the connectors and everything is ok but its still doing it :evil: any ideas, cheers
speeding officer..... you sure?
firestormcrazy
i ve heard about them not too sure about what or how it works tho, i was wanting to see if there was any underlying problem that could be solved before buying that.
Beamish
Post by Beamish »
Warby has one also if my memory serves me correctly, seem to remember a top speed of 160mph stored in it :lol:
firestormcrazy
thanks guys have already pm LotusSevenMan and will see what he says hopefully might get this sorted out. btw it looks like somebody beat me to those cans :x
warby221
Post by warby221 »
Is the 25mph a real speed or is that what’s showing on some one else’s Speedo??
If its real speed say read off a sat-nav remember there’s always a in built error of around 10% and that’s usually on the optimistic side so you don’t inadvertently end up speeding so at 30mph on the clock the real speed would be 27 ish so 25mph is a bit under but not a lot
If your speeds been picked up of some one else’s Speedo then I would say that the gearing has probably been lowered with either a 15 tooth front sprocket or a 43tooth back in that case you would need a Speedo healer or revert back to standard gearing to correct the speedo
Fitting a Speedo healer is easy and programming them is a doddle as long as you follow the instructions word for word
Beamish wrote:Warby has one also if my memory serves me correctly, seem to remember a top speed of 160mph stored in it :lol:
Me never 8O 8O 8O
I’m a law abiding citizen with no interest in braking the speed limit jim :wink:
pariah
Post by pariah »
I would have thought that it would have been a problem with a speed sensor some where that was casuing the fasle reading.
firestormcrazy
hi guys, thanks for the info, when i say im only doing 25 its off my mates speedo and the sprockets are 100% standard, 1st thing i checked, and i ve also replaced the speedo drive.
warby221
Post by warby221 »
Have to have a think on this one
But first thing are you positive your m8 Speedo is correct it could be his that’s out maybe check with a GPS/sat nav and check it at different speeds to it may be reading right at a higher speed
Don’t assume that a replacement part is working ok I spent hours one time on a car trying to get it to run right and it turned out I’d replaced a duff condenser with a new duff condenser
The Speedo works on the same principal as the tacho
The Speedo drive picks up a signal from a magnet/s on the output shaft in the gearbox then sends the signal to the Speedo say how many revolutions of the shaft then the Speedo displays the information as mph
Not a lot to go slightly wrong more likely not to work at all than anything else
There is a way of recalibrating the Speedo but I don’t know how it’s done “never had to do one myself” so probably have 2 go to a specialist and that’s going to cost
A speedo healer is about £65 and can be reset if you change ratios
bikerpiker
Post by bikerpiker »
What about those road signs that flash your speed up on display on roadside when approaching villages,schools etc :?:
I wonder how accurate they are ,i know when i approach the sign in a nearby village it displays 26mph when my car speedo is sayin 30mph :!:
Most likely the signs will be accurate ,wondered if there were any local to you :?:
stevie
firestormcrazy
dnt have access to a gps thingy lol, it have done this test with two m8's both on blades. i wouldnt be surprised if it was the speedo drive since i got it off fleabay lol
firestormcrazy
no just the ones that light 30 up and they dont light up when im doing 30 lol
