Fuel Tank Issue
Fuel Tank Issue
I ride a 2004 VTR and have looked up the specs for fuel tank size. They all say 19. something litres but I can only fit 16 litres max into the tank. I have even run out of fuel and still it wouldn't take 19 litres.
Can anyone help me with resolving this issue?
Is there a special way of filling the tank haha!
Reserve is or was the amount of fuel after the red light comes on but if yours is a late model you will have digi dash and gauge, not sure if you still have a warning light. If you could post a picture of the underside of your tank this can be resolved in minutes.
hi there,
i have an 02 model with the larger tank, there is no reserve tap on the tank, as Beamish says the reserve is the amount of fuel you have after the last segment on the fuel gauge starts to blink on the digi dash, i think it lasts about 25 miles or so max.
i sit on the bike and fill it to the brim, there will still be an air gap at the top of the tank that you can't get fuel into, my guess would be that when they tell you the volume is 19l, they are counting the total volume of the tank not the usable volume that you can get fuel into. can't remember how much i normally get in from near empty but i'd say 16 - 17l is about right, i just remember that my wallet gets crippled every time.
cheerz
kev
kev
Re:
Bringing back up an old topic...kevg wrote:mine doesn't have a fuel valve on the bottom, it's just a fitting with the hoses attached.
Can someone confirm...
On the 19L tanks, if there is just a screw fitting to bottom of tank then where is the fuel tap fitted?
Someone on the SH Forums said that the fuel tap is mounted to the frame?
Not even microfiche's show the 19L tanks and difference.
Just that i have had my 19L tank sitting gathering dust for ages!
Cheers.
