i am about to change my old shitty rectifier for an R6 one, and need to extend the wires as they are a bit short, what sort of wire do i need, can i use any old wire, say off an old radio lead or do i have to use special wire
doggit
rectifier wire
Hi bud
The wire has to be the same as the ones on the original wiring
I’m not a Lecky so cant give you the exact size and number of strands
But the wiring has to cope with a fair old bit of power running through it
Best bet is to chop the same wires out of an old wiring harness if you have one
