Sheared Bolt
stevieVTR
Sheared Bolt
Post by stevieVTR »
F*^K!!!
Sheared one of the rear footbeg bolts which currently hold the bracket for my high level Scorpions. :cry:
Any advice on how to remove the bolt and any idea how much its going to cost?
Anybody?
.... no more bike, divorce sucks!!!!!!!!!!!!!
delmeekc
Post by delmeekc »
oops, which, one of the bolts that goes into the subframe? has the head come off? snapped inside? stuck? etc?
I'm sure it can be fixed, some how.
got a photo?
when dya want me to do it?
can you ride it? (to me)
Del.
stevieVTR
Post by stevieVTR »
The head has sheared off leaving the bolt in the sub frame so the bracket holding the N/S High level can is only held by one bolt instaed of two. I may have cross threaded :oops: as the bolt was tight going in but then again that one was the same when I removed/refitted it last time.
Where is Blue Water?
Stormtrooper
Post by Stormtrooper »
drill out sheared bolt using small drill about 4mm say & use (easy out)type extractor, this should work but you may have to re-tap the 8mm hanger thread though... hope this helps.....
delmeekc
Post by delmeekc »
M25 Dartford Crossing
stevieVTR
Post by stevieVTR »
Thanks Stormtrooper, thats what I thought the answer would be.
Del, I take it thats the same Blue Water as the shopping centre my missus keeps banging on about!!
delmeekc
Post by delmeekc »
yep mate
Del
Druid
Post by Druid »
Stormtrooper wrote:drill out sheared bolt using small drill about 4mm say & use (easy out)type extractor, this should work but you may have to re-tap the 8mm hanger thread though... hope this helps.....
Nooooo, don't be tempted to use a stud extractor, they're one of my pet hates.
Unless you are very careful, it's very easy to break these. So instead of having a sheared high tensile bolt, you have a sheared high tensile bolt with a hardened steel centre. A drill will not make any impression on this, and it will need to be removed using spark erosion - which is not cheap, and will require the subframe to be removed.
Carefully drill out the broken bolt, increasing the bit size gradually. If you get it right you will drill out the bolt, leaving just the threads left in place. These are quite easy to remove using a tap. Alternatively, drill the hole out oversize and tap it to take the next size up - ie 7mm hole, 8 mm tap (I think the footrest hangers are 6mm).
Or take it to someone who knows what they're doing (the very last resort for me) :)
ex-viffer
Post by ex-viffer »
Druid prophesied:
While that's true (i've broken a few screw extractors), if you take it slowly and carefully, use the largest extractor you can (a good quality one), and drill several holes progressively bigger and shallower so you get a tapering hole that fits well, you should be OK. Once you've got it in, wind it in very gently, and slowly increase the pressure on it. Be prepared to quit if it's not budging.
I just did this on my sump plug (see earlier posting), and I was half-expecting the extractor to snap, so treated it accordingly. When it finally did let go, I thought: "Crap! Here we go - it's snapped!", but it was just the sump plug coming loose.
Other things you could do are use a left-handed drill (runs anticlockwise), which tends to loosen the stud as it bites in, or drill a series of holes as Druid says. Worst case scenario with this is you'll bugger up the thread and have to put a helicoil in, which isn't too bad. I've also heard of guys that have gently tapped a stud out using a punch at an angle to loosen it, or loosened one up using heat, but I have no personal experience with those, just screw extractors.
Good luck.
- Ian in EnZed
RQ
Post by RQ »
Interesting stuff, I'm going to have to use similar tools to take out one of the bolts holding the front axle in, as I wrung the head, and now no allen keys will fit the friggin thing. Don't necessarly need to do it, but I'd prefer to do it while I have time, not when I really need to do it.
Anyone else with experience of using those tapper / extractor things ?
RQ.
RQ.
The Stig of 2 wheels as well as 4 !
Yeah Ive yused them in the past.
Would rater reccomend an Impact driver before you get to that stage. If I cant remove a bolt normally I'll pull out the impact driver and a lump hammer(no point doing it by halves) and give it a good whack before I knacker the head. Can save a lot of grief in the long run.
Druid
Post by Druid »
RQ wrote:Interesting stuff, I'm going to have to use similar tools to take out one of the bolts holding the front axle in, as I wrung the head, and now no allen keys will fit the friggin thing.
Use a Torx bit that is a tight fit in the hex hole. Tap it in with a hammer, and it should grip well enough to turn it. It's better if you use a proper bit & a ratchet, rather than one of the bent metal torx keys.
reposado
Post by reposado »
I used an easy out on an old suzuki katana exhaust bolt that had broken in the head...took every thing slow and easy...snapped inside and as mentioned above a normal drill will not touch them, thankfully had a mate who worked in a garage...he got it out, cost me many beers, had to re-thread the hole. :roll:
RQ
Post by RQ »
And here comes the stupid question........Whats a Torx bit ?!?
:roll:
RQ.
The head Looks a bit like a six pointed star
