i would prefer not drilling holes into it, but on the other hand i don't want it falling off after 5 minsWicky wrote:Small pilot holes and some all-singing and self-tapping stainless screws wouldn't go amiss ...
cheers al....AMCQ46 wrote:No screws used cause I thought they would spoil the lines just like you Marty.
I scored and degreased both surfaces and the used a hot melt glue gun, which sets pretty fast so you are not holding it for hrs. then fully filled the leading edge gap with silicon so nowater could get in and force the gap open.
Stayed on no props for 3yrs so far and that includes a few heavy wheelie landings that whip the mudguard to hit the tire!
I remember when I replaced the Ram Air tubes on my 7r - from Factory with joins, seams, resonators etc - to straight through...AMCQ46 wrote:Must have been a bit keen to have to go out in this weather, but you see what I mean about the sound, it's addictivelloydiecbr wrote:Just got back from a 80 mile test run))
Fingers now working .
Wow the noise from the intakes is better and louder than the exhausts .
It pulls better smother and quicker than before I likey
I just need to get the front and rear shocks set now
Sorry officer
The voices made me do it
You should have used a brush ya Daft Git!bigspanishmarty wrote:i did a spot of front brake caliper painting today.
its hard to show the true colour without natural light but i'm happy enough, theres a few spots that need touching up, but i need the paint to harden a bit first.
all i have to do now is scrub the blue paint off me hands......
Take photos before you take it all apart, make notes, refer to Haynes pics for reference, used a combination of these when I did mine & all seems to work ok now it's back together. Good luck & Happy birthday Storm.Stratman wrote:First job in the "Give the Storm a Birthday" has been to remove the rear subframe for painting. Quite how I'm going to get the undertray re-attached with thye cables in the correct places is yet to be discovered - not looking forward to that bit!
Then its all alloy part polished, wheels to repaint, forks to repaint. Fairings off and through clean underneath. Check all connectors for signs of corrosion.
Check valve shims and manual CCTs. Adjust head bearings. Rebuild front master cylinder plus normal "service" jobs.
