Page 70 of 1530
Posted: Fri Feb 10, 2012 6:55 pm
by agentpineapple
Wicky wrote:Small pilot holes and some all-singing and self-tapping stainless screws wouldn't go amiss ...
i would prefer not drilling holes into it, but on the other hand i don't want it falling off after 5 mins :lol:
Posted: Fri Feb 10, 2012 7:05 pm
by AMCQ46
No screws used cause I thought they would spoil the lines just like you Marty.
I scored and degreased both surfaces and the used a hot melt glue gun, which sets pretty fast so you are not holding it for hrs. then fully filled the leading edge gap with silicon so nowater could get in and force the gap open.
Stayed on no probs for 3yrs so far and that includes a few heavy wheelie landings that whip the mudguard to hit the tire!
Posted: Fri Feb 10, 2012 7:43 pm
by agentpineapple
AMCQ46 wrote:No screws used cause I thought they would spoil the lines just like you Marty.
Stayed on no props for 3yrs so far and that includes a few heavy wheelie landings that whip the mudguard to hit the tire!
cheers al.... :thumbup:
Posted: Fri Feb 10, 2012 9:00 pm
by cliveyandrews
AMCQ46 wrote:
lloydiecbr wrote:Just got back from a 80 mile test run :)))
Fingers now working .
Wow the noise from the intakes is better and louder than the exhausts .
It pulls better smother and quicker than before I likey :)
I just need to get the front and rear shocks set now
Sorry officer
The voices made me do it
Must have been a bit keen to have to go out in this weather, but you see what I mean about the sound, it's addictive :thumbup:
I remember when I replaced the Ram Air tubes on my 7r - from Factory with joins, seams, resonators etc - to straight through...
It sounded like it was going to eat babies!!
Posted: Thu Feb 16, 2012 4:40 pm
by marravtr
rear wheel off for new rubber tomorrow, serviced the calliper and put new pads in, new rear disc, fitted the l bracket for the ventura system i got off the bay, fitted one new mirror with built in led indicators (leaving it a da or 2 as dont know if i like em) :? so all in all quite a good day! :D
Posted: Thu Feb 16, 2012 7:50 pm
by Sandyback
Finally finished fitting the R6 regulator/rectifier....... and she started up afterwards - result :clap:
Uploaded with ImageShack.us
Posted: Thu Feb 16, 2012 7:57 pm
by Sandyback
.....and balanced the carbs - they were quite a bit out of sync, see before and after.........
BEFORE...
AFTER...
I'll double check sync when she's all back together.
Posted: Fri Feb 17, 2012 1:58 am
by agentpineapple
i did a spot of front brake caliper painting today.
its hard to show the true colour without natural light but i'm happy enough, theres a few spots that need touching up, but i need the paint to harden a bit first.
the calipers started off like this
then i took them apart and cleaned and sanded them
and then the fiddly bit of painting them
all i have to do now is scrub the blue paint off me hands...... :lol:
Posted: Fri Feb 17, 2012 7:22 am
by marravtr
come up a treat those callipers marty, mates done his red! he used a block of wood with wet n dry after over the nissin wording and rubbed the paint off, neat little touch :thumbup:
Posted: Fri Feb 17, 2012 6:53 pm
by MacV2
bigspanishmarty wrote:i did a spot of front brake caliper painting today.
You should have used a brush ya Daft Git! :lol:
Posted: Fri Feb 17, 2012 7:09 pm
by agentpineapple
you know me mac, i'm still at the finger painting level........ :lol:
Subframe
Posted: Sat Feb 18, 2012 12:13 pm
by Stratman
First job in the "Give the Storm a Birthday" has been to remove the rear subframe for painting. Quite how I'm going to get the undertray re-attached with thye cables in the correct places is yet to be discovered - not looking forward to that bit!
Then its all alloy part polished, wheels to repaint, forks to repaint. Fairings off and through clean underneath. Check all connectors for signs of corrosion.
Check valve shims and manual CCTs. Adjust head bearings. Rebuild front master cylinder plus normal "service" jobs.
Posted: Sat Feb 18, 2012 12:26 pm
by agentpineapple
not much then fella :lol:
happy birthday to your bike :D
Re: Subframe
Posted: Sat Feb 18, 2012 2:35 pm
by MacV2
Stratman wrote:First job in the "Give the Storm a Birthday" has been to remove the rear subframe for painting. Quite how I'm going to get the undertray re-attached with thye cables in the correct places is yet to be discovered - not looking forward to that bit!
Take photos before you take it all apart, make notes, refer to Haynes pics for reference, used a combination of these when I did mine & all seems to work ok now it's back together. Good luck & Happy birthday Storm.
Mac
Posted: Sat Feb 18, 2012 2:44 pm
by MacV2
Played around with some blanking plates, spacers & back plates trying to fill the hole where I've fitted mindicators, no joy so put em back as were.
Did change me gear link rod as mine had some cracks in it. I noticed this way back when I had it all apart earlier in the year only just got a new one, fiver from silvers.
Cracks at both ends one end is cracked both sides.
The worst crack....eek!
Mac
