Page 8 of 13
Re: Project Blue MK2
Posted: Thu Mar 23, 2017 4:37 pm
by bigtwinthing
your good at Polishing, not so sure using a hacksaw!!!. Put a nut on, cut the bolt, wind the nut back, file the edge, wind the nut off, Nicely prepped bolt. Easy in, easy out.
Posted: Thu Mar 23, 2017 4:54 pm
by StormyRob
The nuts look a tad better than they do in the photo. That was just a comparison photo showing how much I had to take off. I did it with a dremel
happy to now be cutting metal for a reason!
Posted: Thu Mar 23, 2017 9:46 pm
by fabiostar
how the hell did you get the forks so polished?
Posted: Thu Mar 23, 2017 9:56 pm
by StormyRob
You should get yourself a polishing wheel kit thing...makes polishing a lot easier.
Posted: Fri Mar 24, 2017 5:45 pm
by StormyRob
Today the side casings were finished as well as the cam covers so I stuck them on. Considering replacing the cam covers bolts but they will do for now. New bolts all round for the engine.
Before its picked up on I am aware the timing inspection thing is also black and it is intentional. It's stuck solid and will be replaced at some point but I've too much to get on with
Anyway here it is...
Sent from my E6653 using Tapatalk
Posted: Sat Mar 25, 2017 7:09 am
by StormyRob
Sometimes it is the little things that be pleasing. I sanded the rotten oil lines and gave them a little paint.
Radiators next.
Posted: Sun Mar 26, 2017 2:32 pm
by sirch345
You're certainly making good headway there Rob, well done mate
The forks, engine, front wheel, six pots and oil lines look brilliant
Which paint have you used on the oil lines
Posted: Sun Mar 26, 2017 2:42 pm
by StormyRob
sirch345 wrote:You're certainly making good headway there Rob, well done mate
Thanks Chris.
I could not get all the rust off the lines as they're so badly corroded. So I've used good old hammerite straight to metal/rust. If it doesn't hold up I'll just do it again but I think it should be OK
Posted: Sun Mar 26, 2017 3:10 pm
by sirch345
StormyRob wrote:sirch345 wrote:You're certainly making good headway there Rob, well done mate
Thanks Chris.
I had a feeling you mentioned Hammerite somewhere, was that spray on, heat resistant or non heat resistant
Posted: Sun Mar 26, 2017 10:51 pm
by StormyRob
Just spray on hammerite. I'll see how it goes after a few runs but I think it should be OK.
Posted: Sun Mar 26, 2017 10:53 pm
by StormyRob
I do not think I need to say how pleased I am to have this.
Posted: Mon Mar 27, 2017 12:16 am
by fabiostar
proper droolworthy yokes...
. lucky man..
Posted: Mon Mar 27, 2017 12:46 am
by Shauned71
Ohhh I like those *dribble* yokes. Very *dribble* nice!
Posted: Mon Mar 27, 2017 1:11 am
by StormyRob
One of a kind literally. Can only thank the man that allowed me to have them!
Posted: Mon Mar 27, 2017 12:13 pm
by StormyRob
Finally an engine inside a frame!
Have to say I absolutely love these
Even a wheel.
