Yes a little depending how you route the fuel pipes unless you have the later fuel spigotWatty wrote:Ah right, every day's a school daylloydie wrote:Not yet but it's a mod I'm testing for piggy as these do suffer with fuel starvation on long fast right hand bends on the track and that's why Roger had them on the mori race bikes .
Pluss when I fitted one to the blade it did have a positive affect on fuelling and gave a smoother but stronger throttle response .
But it's more for the big right handers that I'm doing it and with the larger tank it's easier (I hope) to get fuelling right without the other parts from a later bike .
All being well on the test ride I'll be able to run the tank dry this time :-)Do you think I'll get starvation with the Vara tap?
A vara tap is exactly that, just a tap, no Vacuum diaphragm. There is no way (with the exception of gravity) to feed fuel into the carbs.Do you think I'll get starvation with the Vara tap?
Liking the new avatar Lloyd
Surely both tanks are gravity fed, the vacuum merely opens the tap to let the fuel flow, or am I missing something herecybercarl wrote:A vara tap is exactly that, just a tap, no Vacuum diaphragm. There is no way (with the exception of gravity) to feed fuel into the carbs.Do you think I'll get starvation with the Vara tap?
Liking the new avatar Lloyd![]()
Correct ::thumbup: .Watty wrote:Surely both tanks are gravity fed, the vacuum merely opens the tap to let the fuel flow, or am I missing something herecybercarl wrote:A vara tap is exactly that, just a tap, no Vacuum diaphragm. There is no way (with the exception of gravity) to feed fuel into the carbs.Do you think I'll get starvation with the Vara tap?
It's the routing of the fuel lines I had trouble with as my tank has crap in it so I need to use a inline fuel filter .
If your tank is clean and has a filter in it you shouldn't have any problem with it
Thought so! +1 on the new avatar mate
Thanks I had to buy that pic :-) tho I still like this one more
Yeah that is a cracking piclloydie wrote:Thanks I had to buy that pic :-) tho I still like this one more
I'm going to get both poster printed for the walls in the garage
Yeah I've got one to frame for the living room, photographed by a professional that just sits up the mountain when I was at the tt, well impressed I found minelloydie wrote:I'm going to get both poster printed for the walls in the garage
I remember that one and is a great photo
o
- TravisZack
Took it for a little 20 mile ride to test the tank and pump ,
It feels much crisper and responsive than without a pump .
Just need to do the red light run test now
Do we get more information mate? Pump type, where/how its mounted, pipe routing, pics etc.lloydie wrote:Took it for a little 20 mile ride to test the tank and pump ,
Cbr600f pre injection fuel pump .
3/8 fuel lines.
I mounted mine where the rear Brake fluid res is mounted but just behind the tail plastics .
I wired the live wire to the rear brake light live feed and earth to the rear coil mount .
I'll take some pics next time I have the tank off .
3/8 fuel lines.
