any advice? about to swap my flywheel
Max
Re: any advice? about to swap my flywheel
Post by Max »
hopefully try mine today, have have just taken the 13mm off the flywheel but have HRC throttle already and 15/44 gearing so it could be an interesting morning :)
Max
bigtwinthing
Post by bigtwinthing »
Max wrote:hopefully try mine today, have have just taken the 13mm off the flywheel but have HRC throttle already and 15/44 gearing so it could be an interesting morning :)
you wont need a front tyre any time soon thats for sure.
How did you get on Max. Did you get out on the bike today. Mine had a good thrashing today, two tanks worth all the way down to Bognor and back. Back end slips out a bit when giving it some full throttle if not careful. I also found following cars at a steady 20-30mph on B roads a bit twitchy on the throttle especially when hitting bumps in the road.
Max
Post by Max »
Sorry about the delay work got in the way, managed to get out on the bike wednesday. there is a noticeable difference to the way the bike goes. If i hadnt just renewed the chain and sprockets I might be tempted to go a little higher again on the gearing, that said it does accelerate noticeably faster especially mid range. the other thing i thought was she pulled cleaner from lower revs as well, I was trundling around over the black mountains and theres a couple of bends where she has to chug around normally but she pulled without chugging. I dont know if its me but i think the she changes direction quicker as well, dont know how that bit works it might just be me. Did about 200 miles and I like the change. Top gear work on fast roads took a bit of getting used to, the engine breaking increase is very noticeable at higher speeds.
Max
NZSpokes
Post by NZSpokes »
So how are the super light flywheels holding up?
Whats the sizes on the super light ones?
I feel a mod coming on......
E.Marquez
Post by E.Marquez »
NZSpokes wrote:So how are the super light flywheels holding up?
I have a little more that 13,000 miles on mine now,,,, most of that time spent at 6k rpm or more.
No issues so far... motor gets torn down this coming winter so I'll have a better idea then if it is causing an issue.
(NOTE: No abnormal bearing, crank wear means all is well, some abnormal wear may be an indicator, but not definitive as to it being caused by the lightened flywheel, still it'll be a good look/test)
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
NZSpokes
Post by NZSpokes »
So if I was going to go a bit on the extreme side but not to far, what spec would I take it to?
carmanbikes
Post by carmanbikes »
Flywheel
NZSpokes
Post by NZSpokes »
NZSpokes wrote:So if I was going to go a bit on the extreme side but not to far, what spec would I take it to?
So about to get this done now. Anybody got specs on the most I can go?
Varastorm
Post by Varastorm »
I cut a "mild" one initially, it was fun, but I soon got bored & wanted lighter.
Then I cut an ultra light one to the late Benny's specs (mentioned previously in the thread).
The ultra one is the one to go for in my opinion :thumbup:
You won't be sorry, its a hoot :thumbup:
Varastorm wrote:I cut a "mild" one initially, it was fun, but I soon got bored & wanted lighter.
SHITTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT iv just realised i have that mandrel :confused sorry bout that il get it posted asap.... head like a fecking bucket atm :D
NZSpokes
Post by NZSpokes »
Mine heads off tomorrow, hope to have it back for next weekend. Its 7 6 1/2. :clap:
Or 3.36kg for those in the metric world.
NZSpokes
Post by NZSpokes »
NZSpokes wrote:Mine heads off tomorrow, hope to have it back for next weekend. Its 7 6 1/2. :clap:
Its back and on the bike. Came in at 5.11lb
Or 2.58kg.
Looking forward to a ride tomorrow.
You'll like it :-)
stealthbomber
Post by stealthbomber »
Is anyone still supplying these or is it a case of having one machined? Atb.
In the land of ham fisted, I am king
