Worcestershire Workshop day - May 13th
Moderators: AMCQ46, geodude
Dates for Midlands workshop
Poll ended at Tue Feb 21, 2017 11:35 am
April 29th
0
No votes
May 6th
2
33%
may 13th
4
67%
Total votes: 6
Re: Worcestershire Workshop day - May 13th
Yes I'm on the bike.
I was just saying that I could put stands in my car.
It's not much help, as I won't be in the car, but I like to join in.
Pls bring the abba bits
No Problems Tony. See you there :thumbup:
tony.mon wrote:I'll also be replacing front and rear wheel spacers with lightweight captive ones and fitting a new clutch pack into the slipper clutch.
Have you got a 1/2 inch drive breaker bar and large torque wrench?
Might as well get a couple of little jobs out of the way.
yes, have both
podman wrote:Ill be with you around 1pm bud, does that still give us reasonable time to do the stopper mod? Do I need to bring anything with me?
Much appreciated.
we should be able to do it in an hour and a bit as long as the inspection caps are not seized. have you tried to see if they come out?
bigtwinthing wrote:iam i getting a trip up to feed the horses?
will ask but shouldn't be a problem as long as they are not out racing
Much appreciated.
I'll bring a spare slightly battered but useable on in case it puts up a fight.
bigtwinthing wrote:
bigtwinthing wrote:
alanfjones1411 wrote: Warwick services just before turning off m40 I think. Better check though
does anybody want to meet in the Warwick services for 0800-0815 ?
thats about 30 miles from the "big Fry up " , i can do later if you wish. or if your embarrassed to be with a Triumph i can ride behind you. ( no "slow anyway " comments kev)
I will be merging with the M40 from M25 about 8:00.I stick to the speed limit cos i've got 9 points.So if you're behind me you'll probably catch me up.Worked out fuel stop and will want fuel at Warwick services.
podman
Post by podman »
tony.mon wrote:
Much appreciated.
Thank you, very kind...PS What and where are said inspection caps, I will try and give them a tweak this afternoon if it stops pissing down...
podman wrote: Thank you, very kind...PS What and where are said inspection caps, I will try and give them a tweak this afternoon if it stops pissing down...
Left hand side Generator cover... The big one is the bastid 10mm allen IIRC...best give it a good soak with Plus Gas over night. Give it a tweak to see if it moves but if it's stuck it will just chew up, so if it starts to chew leave it alone & let Tony at it with his hammer...
bigtwinthing
Post by bigtwinthing »
i will google that and get back to you.
bigtwinthing
right Alan, i will get to the oxford/m40 link about 0830, so may well see you on the M40. i will look out for a nice Storm.
bigtwinthing
Stay safe Guys, riding up. and back.
Have fun chaps and keep em upright ( the bikes Lloydie, the bikes ) :thumbup:
Have a great day lads
Have a good day chaps....
Would have joined you today but I have the Murvinator coming round with his broken Storm & a replacement engine...Oh & Vanstub as well to finish his bike off...
No barbieQ for us.
Good luck with putting up with Tony's jokes.
Keep an eye on Lloydie if he shows up...backs to the wall if he has lube in hand...
Keep the grease off Alisons white stilettos...
Well I'm at work so watch out for a pink truck !!!.
I might still make it
