Page 851 of 1532
Posted: Mon May 04, 2015 11:26 am
by Ckennedy
lloydie wrote:More cleaning , some painting , more lubing ,
I'll start the rebuild tomorrow .
How you like them tyres ck ?
Lube, no lube, it's your choice .
They seem ok. Not loads of feed back from them but they seem to hold there own and haven't stepped yet (well apart from me being slightly to lairy on a cold new front
) now I've had to take this missing clothes shopping for a funeral tomorrow I'm going out again for a few hours to really try pushing them, and myself
Posted: Mon May 04, 2015 1:05 pm
by kenmoore
Into the Cave for a strip down and a good going over including valve check/adjustment.
We have had monsoon type rain on and off for the last fortnight which is unusual for this time of year.
Intend to take my time and do it properly.
While I'm in there I will check the timing chain to see if the manual CCTs need tweaking.
Lots to do still but the air box is of, next are the plugs and valve covers.
Will do the rear first as it is easier!
Will try and post some detailed pics as I go.
Posted: Mon May 04, 2015 3:31 pm
by MacV2
Bit O'Fettlin on Smokin Joe.
Put on the F2 bars & Renthal grips on & whilst there added a QAT.
Posted: Mon May 04, 2015 6:39 pm
by lloydie
More tidying up and started the reassembly
Hope to have it finished this week then it'll be on eBay
Posted: Mon May 04, 2015 6:41 pm
by bigtwinthing
lloydie wrote:More tidying up and started the reassembly
are you offering on here first Lloydie. Iam still trying to get my mate to buy one, he has the cash waiting.
If you can post some pics and some spec etc pls.
Posted: Mon May 04, 2015 7:14 pm
by lloydie
Yes . I can txt you some info and I'll have pics towards the end of the week
Posted: Mon May 04, 2015 8:00 pm
by agentpineapple
lloydie wrote:Yes . I can txt you some info and I'll have pics towards the end of the week
can't believe you won't be on the snot rocket in devon.....
Posted: Mon May 04, 2015 8:11 pm
by lloydie
I might be if it hadn't sold by then lol
Posted: Mon May 04, 2015 8:15 pm
by VTRDark
That's it Save the Snot Rocket... nobody buy it.
Posted: Mon May 04, 2015 10:25 pm
by Watty
Eh
What's going on? Since when was it getting sold Lloydie
Posted: Tue May 05, 2015 4:15 am
by lloydie
I've been thinking about it on and off for a year now . It's time to get something else for the road ,
I will finish the pig now tho ,so I'll still have a storm and it'll be better that I originally planed too
Posted: Tue May 05, 2015 12:19 pm
by Cadbury64
Fitted up the CBR954 callipers and master cylinder today. I bought these off EvilBay from a seller in the eastern USA, they were said to be in good order bar a seized lever. The lever assembly came off nicely but the piston was jammed. A few light hammer taps got it moving inward and I was able to tap it back out once I had the banjo off so I could drive it back out. Turned out to be some crystal deposits which cleaned off easily enough, and the bore and piston were perfect. Looks like the original pads, half worn, and the callipers and pistons cleaned up a treat.
I opted to file the relief into the fork legs, leaving the outer face untouched for a stock appearance and not touching the callipers at all. Ended up with a snug fit but the bolts went in smoothly.
Looking at the 954 lines I decided to re-use the Storm lines, as the brackets that tie the hose to the fork leg looked unusable on the 954. Drained all the fluid out of both systems, disassembled both and then swapped the master and callipers leaving the hoses in place. Used my vacuum bleeder and got a pretty good lever feel. I might go the whole hog and add some braided lines in the near future as even with a good bleed, I can feel the lines bulging a little.
Also on my list, replacing the rusty Torx bolts with something shiny. Can anyone advise the size and grade I need?
Posted: Tue May 05, 2015 6:22 pm
by 8541Hawk
Getting ready to go pull the carbs one more time......lol
Really close with the jetting now after a few more tweaks but now I need to raise the needles 1 shim.
No can't be an easy adjustment to get things dialed in to my liking.....
Oh well besides a little cough at 4K from time to time running real strong now
Posted: Tue May 05, 2015 6:27 pm
by 8541Hawk
The sizes needed are 8X35 and 8X40 with a pitch of 1.25 as for the grade....good ones of course.....
Posted: Tue May 05, 2015 7:34 pm
by Cadbury64
Thanks Hawk; I'll go shopping today.
