I just showed her and guess
She loved it !!
kev64 wrote:That is very pink !
She loved it !!
Your wish is my.....horselg wrote:Legendlives, can you give some details of your bobbin fitting.
They have had the baffels removed...The Full Baffeloctmemy...Cadbury64 wrote:Can anyone confirm whether these mufflers are "stock"? Bought off our local auction site, they have a much bigger outlet than the ones on my bike. What do you reckon?
Is that just a case of putting a big hole-saw down it Mac?MacV2 wrote:They have had the baffels removed...The Full Baffeloctmemy...Cadbury64 wrote:Can anyone confirm whether these mufflers are "stock"? Bought off our local auction site, they have a much bigger outlet than the ones on my bike. What do you reckon?
Sent from my iPhone using Tapatalk![]()
Any easy mod to release more db...will sound good when fitted try them...
Here's a set I did earlier...
Been away for a few days so possibly the worlds slowest response (although the wife might say it was quite normallloydie wrote:Is yours red ?Geoff S wrote:Not really today, more last weekend.... Got rid of the Renthal handlebars that have been on there since I got it. Replaced with some old Fireblade clip-ons as it has a very early 'blade fork on it. Handling feels better and less wheelie prone at the same throttle but damn they are low (non-standard top yoke means they sit lower)and hard on the wrists. They are staying but maybe some thought required....
You could do it with a hole saw but I've never seen one thats for metal...only wood...What is the norm is to drill a series of holes around the spout, the more the merrier. Then take a cold chisle & join the holes up. That will leave the inner spout flopping about side to side...Now you have to break the weld at the far end of the baffle. Whack it with a hammer use a bit of wood so you have whack room so as not to damage the outer spout. Whack it in as far as it will go, use a pire of mole grips to then pull the inner spout back out, repeat until the weld breaks...Pull out inner spout compleat with the baffle & throw that in the bin! Repeat with the other pipe. Finaly use a die grinder or Dremmel type tool to clean up the inner edge wher you have drilled it...Simples, & sound nice...only real issue is that they still weigh loads...legendlives wrote:Is that just a case of putting a big hole-saw down it Mac?MacV2 wrote:They have had the baffels removed...The Full Baffeloctmemy...Cadbury64 wrote:Can anyone confirm whether these mufflers are "stock"? Bought off our local auction site, they have a much bigger outlet than the ones on my bike. What do you reckon?
