raised my needles and unblocked the slide life hole as it was un-ridable :( .
took it out for a test all is good but now needs a clean
Rob
Post by Rob »
Removed LH switchgear, cleaned and packed with vaseline! Hopefully high beam switch will stop sticking now... Any other advice for that?
Went to work on it yesterday, 32 miles at 0 deg (5 am) wasn't comfortable, even with heated grips. Nice sunny ride home at 2pm made up for it though :D
'02 VTR1000-FY Yellow.
chi kung
Post by chi kung »
Didn't use any laquer just good old hammerite smooth. Also the Nissin just came up like that when I cleaned it. If you strip your calipers the best product I found to clean them is wonder wheels. Be warned though its about £50 for new seals.
edds11
Post by edds11 »
slappa, I presume its an apple phone you have, hence the usb, why not just buy a car charger for the phone (cigarette lighter fitting) and put a normal 12v socket up there.
tankslappa
Post by tankslappa »
edds11 wrote:slappa, I presume its an apple phone you have, hence the usb, why not just buy a car charger for the phone (cigarette lighter fitting) and put a normal 12v socket up there.
Go wash your mouth out! I've got a 'droid :p
Anyway, 12 sockets are big and clucky, as are the plugs, and they rattle loose. A USB locks in far firmer. I've done this mod to the car too, mounted a USB socket in a blanking plate, works great. It just needs a 5v regulator and a little capacitor.
Anyway, that job is easy, compared to the package I received today...
No idea what these bits are for! (Update, worked it out, they're key adapters for mounting the original key onto the alarm fob).
Oh well, at least I have supplies
That alarm is looking good mate, you'll have fun installing that. :thumbup: I hope it's not one of those that beep every so often to let you know you have an alarm installed. Beep Beep Beep :lol: The only way you can stop it is to disconnect the power.
And the usb, that's a genius idea. Only one problem though, the one you have is an Iphone only device :wink: :lol:
Have Fun :thumbup:
tankslappa
cybercarl wrote:That alarm is looking good mate, you'll have fun installing that. :thumbup: I hope it's not one of those that beep every so often to let you know you have an alarm installed. Beep Beep Beep :lol: The only way you can stop it is to disconnect the power.
I find an axe also works!
Disconnecting the power on this one won't help either, it's got battery backup! Anyway, no, it doesn't go "beep" all the time. I've got the super secret installers manual, so I know how to change the program. The manual says "enabling arm/disarm beeps is strictly forbidden in Europe"... Really? Since when? My car certainly goes beep beep, so I think my bike will go beep too.
£120+vat from Bikers Discount Store and the fun of fitting it myself is way better than £400 fitted price... Not sure what I'm going to do with the registration doc though, it wants details of the fitter :-(
Does a professional IT and electronics geek qualify?
And the usb, that's a genius idea. Only one problem though, the one you have is an Iphone only device :wink: :lol: (:-})
Thanks ya cheeky git!
Now where should I put the flashing LED... I quite fancy the idea of using the fuel level warning LED on the clocks, that would be neat... Hmmm... Oh well, I have a spare set of clocks (somewhere!), time to find them and pull them apart... and make another cuppa tea!
Where do you guys have your flashing alarm LEDs?
I was not talking about the enabling/disabling. Some of them you switch on, walk away from the bike and they beep every minute or so untill you switch the ignition on! And yeh, since when :?
On mine the led is fitted (not by me) on the rear panel, right hand side, next to the seat lock. Alright for someone to see from behind and it's in quite a well positioned place. I personally would have that one and another up front incorperated into the clocks somehow.
As far as getting you paperwork stamped, you need to go to an authorized fitter (as you are not :lol: ) and explain to them you know what you are doing as a fully qualified electronics geek. Let them have a quick look over what you have done, get them to sign it off, stamp you paperwork and give a drink :beer: Sorted.
Have Fun :thumbup:
Snoogle
Post by Snoogle »
Installed some relays for the twin headlights that are now running mega high output (off road only :shh: ) bulbs...should be able to see at night now :lol:
Also put the super bright leds somebody on here recommended for the clocks, makes a massive difference :)
spider13
Post by spider13 »
been doing a bit of bsm today,not bad for first go
http://i645.photobucket.com/albums/uu17 ... pan003.jpg
steve
The big man has competition! That's looking good spider, don't forget to lacquer it as well, give it some protection. :thumbup:
tankslappa
cybercarl wrote:The big man has competition! That's looking good spider, don't forget to lacquer it as well, give it some protection. :thumbup:
Ah yes, but do you think Spider can pull off pink?
tankslappa
Well I've continued my alarm mission tonight. Having spent last night staring at a too small wiring diagram for the bike I decided to go and see what things look like in reality... so first step, rip the back end apart (again!).
Second step, start opening up the loom very carefully with a knife...
And then try to identify the wires! The cable ties you see there are round specific wires (or pairs) as I identify them.
This is just the first venture, I've got other wires to find which is going to entail adventures into other parts of the loom, and further down this one... Be afraid, be very afraid!
spider13 wrote:been doing a bit of bsm today,not bad for first go
steve
thats good buddy, i would say thats a very tricky thing to wrap, lots of angles to deal with, what would you score it from 1 to 10?
if you laquer it, it seems to shrink/tighten a little, which is ok but it will highlight any creases, on the plus side 4 or 5 coats will give it a nice deep glossy carbon look, just don't get to close with the laquer, i think the halfrauds stuff is good, i didn't like the simonz laquer tho.....
oh and only real men can get away with chameleon wrap, NOT PINK!!!!! :lol: :lol: :lol:
spider13
Post by spider13 »
cheers mate im going to have a go at laquering it later today,it was very difficult with all the curves and thers a couple of creases but you wont really notice them being at the bottom of the bike,id score it around a 5 could be better but iff i try it again it could be even worse,ill let you no how i get on with it
cheers steve :thumbup:
ps ive wrapped the seat cowl for now aswell im going to leave doing anything else to it till the winter
