Posted: Mon Jan 25, 2016 5:28 am
Oh yes many many times ,unless you take it for a Dyno tune and let them do it ?.
The UK's Number One FireStorm Website
http://www.vtr1000.org/phpBB3/
on unmodified engine, I would start with Fpro needles - clip on the top both (leanest setting), main jets 178+180 or 180+182 with aftermarket filter, and 48 pilots. That should give you good start, and try to tune pilot jets screws if you have problems till 5k rpm.mellis wrote:Tempting but I like tinkering, I also like whinging about it when it gets difficult
Thanks mate, that sounds like a great starter for ten!Stephan wrote:on unmodified engine, I would start with Fpro needles - clip on the top both (leanest setting), main jets 178+180 or 180+182 with aftermarket filter, and 48 pilots. That should give you good start, and try to tune pilot jets screws if you have problems till 5k rpm.mellis wrote:Tempting but I like tinkering, I also like whinging about it when it gets difficult
My experience is, that these needles work well only with clips on the top or one slot down.
with paper filter, I ran 178+180 with Dr Honda Stacks and full exhaust system. And it was not too lean :-)mellis wrote:Thanks mate, that sounds like a great starter for ten!Stephan wrote:on unmodified engine, I would start with Fpro needles - clip on the top both (leanest setting), main jets 178+180 or 180+182 with aftermarket filter, and 48 pilots. That should give you good start, and try to tune pilot jets screws if you have problems till 5k rpm.mellis wrote:Tempting but I like tinkering, I also like whinging about it when it gets difficult
I'm on a stock air filter but the cans seem to be very free flowing so will go with 180 front and a 182 rear. Will also try the first slot down and then work the pilot circuit to see if I can iron out any glitches.
Stunning! Got a real soft spottempl8 wrote:Thanks fellas, fitted them to the bike now. I can move around the workshop now.
Sent from my SM-G850F using Tapatalk
Me too, excellentPete.L wrote:I'm liking that
