To put your mind at rest regarding the front drive sprocket.Isacc wrote:One thing that bugs me relates to a query I put into this forum earleir this year.
When I went to fit the chain and sprockets, there was lateral play on the drive shaft sprocket, i.e even with a new bolt and washer torqued up properly you could still feel play in the sprocket along the direction of the shaft, not on the splines itself.
One chappies reckoned this was normal, but if any of you get the chance, I'd be interested to see if its the same on your VTR. (You can get your hand in behind the clutch mechanism cover quite easily)
I've had my bikes rear end stripped down this week for servicing etc so I purposely checked the front sprocket for you.
Mine has the original sprocket fitted from new (20,000mls done now) and it does have play along the direction of the shaft, also on the splines itself. Probably a new sprocket would have less play on the splines itself more like yours.
So from that IMHO I'd definitely say yours is normal
