That made me giggle Chris, although tanks are easy as they are automatics! Although i must make a small correction, tanks fire on the move, guns don't!!! Being a Gunner i would be failing the Artillery if i didnt point that out!!!sirch345 wrote:![]()
Is it because you're used to driving tanks![]()
All joking a side Mark that is unbelievable![]()
You are not going to believe this.........
Re: You are not going to believe this.........
You're gonna have to change your tagline.....
Or your boots
Looks good, when you fitting the quickshifter?
Or your boots
Ah well it was only a guessmellis wrote:That made me giggle Chris, although tanks are easy as they are automatics! Although i must make a small correction, tanks fire on the move, guns don't!!! Being a Gunner i would be failing the Artillery if i didnt point that out!!!sirch345 wrote:![]()
I see you haven't wasted anytime in getting yourself back on the road
