BLOWING AT THE LINK PIPES. URGENT
Phil-VTwin
Re: BLOWING AT THE LINK PIPES. URGENT
Post by Phil-VTwin »
i just used the standard stuff, it smelt whilst it was "burning off" but sealed the joint up well and has lasted longer than the firegum did. :)
Ride Safe
Phil
tattie
Post by tattie »
I always used high temp RTV silicone sealant, warm it up after fitting, leave it for a while and then give it a gentle run. It flexes as opposed to the repair paste which will crack in a short while.
A.M.
Common sense ain't all that common!
Jbrebel
Post by Jbrebel »
Yep-standard stuff.
Every exhaust fitters I've used has done the same.
SP1's rock!
Thanks guys for the info on silicone type :thumbup:
knuckledragger
Post by knuckledragger »
My Big Bruvver used to own Redline Race Cans and all the joins were sealed using heat resistent silicone. It's especially ideal for joining link pipes etc.
I did reply a while back to some dude who was having problems with his bike backfiring on over run.........this is caused by air being sucked in to poor fitting pipe link joints. A quick smear (and smear is not a rude word BTW :redface ) with some heat resistant silicone and you will no longer have war veterans diving for cover every time you ride through town :thumbup:
Regards
chuxsta
Post by chuxsta »
guys that have used the siliocone sealant for the link pipes what sort did you use?
and what sort of heat range should the selant be able to take?
i have some i use for gaskets, stands up to 250 degrees, is that enough for down pipes.
