Battery
Re: Battery
Yes Chris ,Had a standerd ytx12 in it before this and the 14 fits in so easy a little bit of slack is needed on the - side but apart from that its a direct replacment.All the best Balls/Neil
Re: Battery
Thanks for the info Neil,balls wrote:Yes Chris ,Had a standerd ytx12 in it before this and the 14 fits in so easy a little bit of slack is needed on the - side but apart from that its a direct replacment.All the best Balls/Neil
Cheers,
Re: Battery
Well kicks it into life a lot better ,think this is a good mod along with a r1 reg/rec
Re: Battery
Neil,balls wrote:Well kicks it into life a lot better ,think this is a good mod along with a r1 reg/rec
A bit more umph is just what you need this time of the year. Iirc your battery has 20 more CCA (cold cranking amps) 180 instead of 160.
