Done it!!! Job done!!!
Fitted R6 (6 pin rectifier) as directed by 'The Man' Phil-Vtwin (ta very much). Followed instructions religiously - ignition on - Nothing / dead / not even a flicker.
Hmmmm. Have I bought a duff part off fleabay??? possible but unlikely.
Hmmm.... I question myself - have I connected it right????? possible and probable (but nope - all OK).
Hmm..... where's that f@=+in' multimeter??????
1. Check connections and earth again. OK so far
2. Check battery - OK 12.55V constant. Still OK
3. Check power Main fuse - left side OK, right dead...ah!! Main Fuse blown!
4. Realise that the red wire on regulator is permanent live and will fuse if earthed - Doh!!
5. Replace fuse - bike fires and getting constant 14.26V charging....success.
6. Dance about garage.
7. Get leccy tape out to seal the connections ....ah leccy tape. Isn't always the case; always got tape(?) NOOOOOO!
8. Search madly around garage for the elusive roll.
9. Nip next door borrow tape and finish off the job.
Here's what I've learnt:
1. If doing this either disconnect battery or tape up +ve lead.
2. Always have leccy tape!
3. Buy a spare main fuse - just in case.
HAPPY FETTLING......I'm off for a beer
