inTech vacuum control system?
Re: inTech vacuum control system?
is it possible to use them with the 16l tank as it has a vac tap ?
or would i need to change it to a proper tap ?
mik_str
Post by mik_str »
Little buggers are a bit of a challenge to find but I finally located a model which uses a 3/16" inlet so I think I will try to hook up both cylinders to it via a "T". This will likely become a winter project..... The fact that you got yours to work inspires me to try it too (albeit slightly differently).....
mik_str
Post by mik_str »
Well, I am taking the plunge, lol
Inspired by Benny, I finally found (what I deem to be) a suitable valve:
http://smartperformance.net/product_inf ... ucts_id=34
I just ordured one up (less the elbow on the far left side) and will be hooking it up to both cylinders via a T and the necessary hoses. Hopefully it will work as well as Ben's......
nice one mik... im sure you will find an improvement in cornering speeds as you will be able to coast in like a 4...
and coming down the box into a bend there is no wheel hopping engine braking, or very little depending how you set the valves up.
probably best to run them outside the airbox to get the setting right then when youre happy with the effect you can mount them under the air filter.
lloydy all i did was attach it to the balancing lines... doesnt matter what tank you have assuming you have 2 vac lines from the inlet ports.
mik_str
Post by mik_str »
Ben,
what side are the balancing lines needed?
cheers
Nice one I will be doing this mod then after I get a flywheel tuned down thank you
Can't ride but it don't stop me trying
mik_str wrote:Ben,
cheers
i mean the carb balancing hoses, from the little adapters on thr intake stub under the carb.... this is why it doesnt need to be a big valve.
mik_str
Post by mik_str »
Thanks Benny,
there was a typo error in my question. What I meant was what SIZE are the hoses needed (ones taht come off the vacuum feed). I will have to get some so may as well know what size I need (will also need to get a T with a 3/16" end on the solo side and small ends same O.D. as the vacuum port).
thanks in advance
mik_str wrote: what SIZE are the hoses needed (ones taht come off the vacuum feed)
:biggrin
it would depend what type of vac adapters you have... i used 4mm id hose
