Gaskets
Re: Gaskets
Great idea Seb421, we shall have a whole set of paper gasket templates in the end. Will save user's a fortune. :clap: Just so you know, your mediafire link is down. not sure if mediafire have removed it for copyright infringment :lol: whicky's links (no pun intended :lol: ) still work.
Not saying your templates are copywritten but mediafire scans it's system and if they see the word Honda, might mistake it for somthing else.
When uploading stuff to mediafire or other fileservers it's best to put the file inside a zipped folder, then put that zipped folder inside a folder compressed in the rar format with a password. Name that folder somthing generic so that when medifire scans it's system for copywritten files it can not see anything.
Keep up the good work. :thumbup:
seb421
Re: Gaskets
Post by seb421 »
Thanks for letting me know carl, i will re upload else where soon,
when i get an A3 scanner i will uplaod the large clutch gasket tony was good enough to lend me one but was unable to scan it at the time as my A3 scanner is missing and works is shagged
KarlosVTR
Re: Gaskets
Post by KarlosVTR »
any news on these pal? can you actually buy the funny blue / green gasket paper?
seb421
Re: Gaskets
Post by seb421 »
KarlosVTR wrote:any news on these pal? can you actually buy the funny blue / green gasket paper?
have a look on ebay, lots for sale
Re: Gaskets
Hole punches are probably a good investment too.
http://www.ebay.co.uk/itm/9pc-HOLLOW-PU ... 3f116d61fe
And a good sharpe blade!
A scalpal is my personal favourite. :Fence:
KarlosVTR
Re: Gaskets
Post by KarlosVTR »
http://www.ebay.co.uk/itm/Gasket-Paper- ... 20b009e86c
that stuff?
are you able to host the pictures somewhere? or are you waiting to scan the clutch one so its a set?
dragonback
Re: Gaskets
Post by dragonback »
nice job , very handy will use it soon too , :clap:
DOES THIS RAG SMELL LIKE CHLOROFORM TO YOU ?
seb421
Re: Gaskets
Post by seb421 »
KarlosVTR wrote:http://www.ebay.co.uk/itm/Gasket-Paper- ... 20b009e86c
that stuff?
When i get back in tonight i will post it up mate, off to work shortly but might have it done before i set off, gotta get tea on now
seb421
Re: Gaskets
Post by seb421 »
Here you go mate, follow instructions from previous re-printing
http://ukbiker.me/Firestorm-Gaskets.pdf
Re: Gaskets
There's stuff a lot cheaper than that. It does not have to be Green!
http://www.ebay.co.uk/sch/i.html?_from= ... sket+paper
In the past on cars, I have just used a bit of cardboard, because basically that's all it is except it's oil and water resistant. You do get cork gaskets as well. And head gaskets are generally lined on the inside perimeters, cylinders, water holes etc with tin/ally, hence the expense.
But in this case, these are just your cheap cheerful cardboard type. :wink:
KarlosVTR
Re: Gaskets
Post by KarlosVTR »
I don't want to use just chopped crushed cardboard. I thought the blue / green material was oil and fuel resistant whereas the paper card mess was just for thermostat housings?
This rover v8 I just rebuilt gas every type of gasket material available used on it!
Re: Gaskets
I wasn't suggesting you use just cardboard, but pointing out the option of cheaper alternatives out there on eBay which are water and oil resistant.
We never know on forums what someones financial status, knowledge or skill level is. Just trying to helpful Karlos!
Anyways, seems like you know what you are doing. :thumbup:
KarlosVTR
Re: Gaskets
Post by KarlosVTR »
my apologies carl i was at work and had to bash in a sneaky reply before i got busted, i didnt mean to come across as facetious.
what i mean is theres different gaskets to do different things. as an example the v8 has a papery one for the water pump, composite tin / weird stuff for the inlet, metal compression for exhaust and head and a totaly crap cork affair for the sump. my volvos original engine had a greeny bluey one for the inlet manifold for fuel resistance i guess. so really i would say the greeny blue stuff wins :thumbup:
Re: Gaskets
No worries mate I understand.
Who's being a naughty boy then :lol:
I don't have that problem as I'm self employed. Could do with someone looking over my shoulder cracking the whip at times, as I get easily distracted by thing's like this, eBay, the list goes on.
seb421
Re: Gaskets
Post by seb421 »
Has any one else Noticed the Bromance between these two? hahaha
