update.......
ridden in torrential rain, sleeves dry!!
paintwork was too gaudy, gone back to satin black. gotta move the sidestand up a bit, it ploughs furrows on left handers.
the stainless auxillary fuel tank under the seat split and sprayed fuel all over the rear downpipe. gonna do away with it and fit a leather pannier on the left side with a fuel cell in it. wasn't sure if i'd take to the bars or not, but they're great!!!
handles fine as long as you avoid the big pot-holes, single HSR 40mm flatslide mikuni on my home made stainless manifold works a treat, i guessed the jetting and got it spot on first go! (pilot screw 1 3/4 turns out, needle on centre clip, 2mm drill thru the main jet), no hesitation, no flat-spot, pulls like a train, goes like f*ck.
When subjected to an electrical voltage of at least 50 volts, a cat's tail always points toward the north.
