Red Storm
Re: Red Storm
Jester666: I forgot the spring, must be from cbr as well ...
Re: Red Storm
Silver 1998 'Storm! That keeps trying to kill me! And is leaving me soon!
Re: Red Storm
How much did you take off the flywheel and what is the effect? I have an old cbr600 motor in my shed and I think the rotor may fit if I swop the sprag clutch over.The standard one looks a bit meaty hanging off the end of a skinny shaft.
Re: Red Storm
i like it
do those fork braces make much difference ? ?
Re: Red Storm
New diameter of steel rotor is 146 mm, and thickness 10.15 mm. I have no idea if CBR600 fit. Effect is that engine is more revvy, and front wheel goes up more times, no negatives from my side :-)oldbikeman wrote:How much did you take off the flywheel and what is the effect? I have an old cbr600 motor in my shed and I think the rotor may fit if I swop the sprag clutch over.The standard one looks a bit meaty hanging off the end of a skinny shaft.
Re: Red Storm
I believe yes, front is more stable, but it is hard to say.lumpyv wrote:i like it![]()
I must say today that going with CBR954 front-end seems to be better idea than expensive reworking of these forks, but as I know me, I´d want to put racetech stuff into these upside down forks too, so at the end, it´s been even more pricey ... :-) Plus I like the original bar position, in spite of much people change it.
Re: Red Storm
A very well sorted bike there Stephan
She looks good and is in the best colour too IMHO
Re: Red Storm
Out of curiosity can you remember what clip positions the needles are on and how many turns on the A/F screws.FactoryPro Ti needles, 180+182 main jets, 48 pilots
I'm currently waiting for my kit to turn up, so doing some research on various settings and setups.
Putting my 6mm spacer in at the weekend so thanks for enlightening me to the sidestand issue.
Re: Red Storm
cybercarl: rear needle in the middle, front one slot up (to get needle lower), plus plugged one slide hole on front. A/F I don´t know, it was done by Idle Drop Procedure described in manual.
Re: Red Storm
Thanks Stephen I understand the front needle being a slot up to lean it out a bit as the rear should run a bit richer to cool it down. But why the plugged slide hole with the two long stack's or are you referring to a third (dynojetted) hole.
Very interesting.
Very interesting.
Re: Red Storm
Plugged front slide hole (not third dynojetted, but second oem) is per Roger´s D recommendation - to adjust front needle slide speed a bit and get smoother engine run - whether you have long stacks or not, doesn´t matter. For sure it is not applicable for carbs with dynojet kit mounted with different springs and added slide holes.cybercarl wrote:Thanks Stephen I understand the front needle being a slot up to lean it out a bit as the rear should run a bit richer to cool it down. But why the plugged slide hole with the two long stack's or are you referring to a third (dynojetted) hole.
Very interesting.![]()
Hawk8541 on US forum recommends the same, and it seems to work well :-)
Re: Red Storm
some new photos with new stuff ...
Re: Red Storm
i like it alot . what are the wheels from ?
Re: Red Storm
very nice
what make are the lowers ?
cheers
cheers
