only keep the rolo biscuits for me......dont know how he found them, must have been when I was out test riding to check we had the setting right.
That wikipedia link is gross
you are going to have to change your screen name again Shaun, as every time I see you on here I will link it to that image...........you dont want to be known as Shaun with the sore Richard
it is fun doing someone elses bearings as shaun was shocked about how much violence you have to apply to precision parts..........trick is what you put between the large hammer and the precicion ground parts
what is a pain is the amount of bits that need to be reomved and then refitted to get the yokes out, other than that its a quick job getting the bearings swapped over.
Oh and we forgot to take any photos of the work other than where the cables are routed each side of the forks.........blame Shaun for that it was his job!
