Frame covers
nora2004
Re: Frame covers
Post by nora2004 »
thumperslaw wrote:Got them today and they look smart! :thumbup:
The fit on the other hand :thumbdown: crap
Not the best is it! Lol
As you can see from mine I had to cut sections away, cut the meeting points straight then used some sticky carbon vinyl to hide the joint!
Word of advice when cutting it wear long sleeves, he fibres had me itching for days! Lol
Re: Frame covers
nora2004 wrote:Here we are, all done!
your bikes crying out for some carbonardi engine case covers matey.... :thumbup:
thumperslaw
Re: Frame covers
Post by thumperslaw »
You have a pm
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
Re: Frame covers
Nora, have you got your rear subframe jacked up to lift the seat up higher?
Re: Frame covers
AMCQ46 wrote:Nora, have you got your rear subframe jacked up to lift the seat up higher?
Looks like it to me
Re: Frame covers
I don't understand why they didn't bother to extend the rear bit to cover it all. You have done a good job with the join there Nora. Look as good as it can. :thumbup:
nora2004
Re: Frame covers
Post by nora2004 »
Already ahead of ya, got them on order, just waiting for delievery! lol
Is it that noticeable? Ive dropped the bars as much as I can without loosing the fairings, about 1 1/2 inches, so the only other option was to raise the rear an inch or so to allow me to sit in the bike instead of on it, gives it a proper "sportsbike" riding position! Plus it makes my numberplate easier to read! lol
cybercarl wrote:I don't understand why they didn't bother to extend the rear bit to cover it all. You have done a good job with the join there Nora. Look as good as it can. :thumbup:
Cheers, I was unsure of how they would look once on, but they look like theyve grew there!
Right then, in the picture below, the red circle is where I had to cut away a piece, its the bottom lip that would go under the frame, I just cut it in line with the rest of the cover so that from the shock end to the front wheel end is one straight line now!
The edge of the "Y" piece, the blue circle on mine was all wonky, I simply used some masking tape to get me a straight line and cut it so its now perfectly straight and would pretty much meet up with the upper piece!
I then had to cut a notch out on the underside where the green circle is to clear the frame welds, or else it was pressing the cover out!
I wouldnt bother with silicone neither, I tried it at first but its just not strong enough, on mine where the blue circle is, I had to use a G clamp to hold it against the frame whilst the adhesive set or it was sitting proud about 5-6mm! lol
Once the bottom piece was on and set I then stuck on the top halfs aligning them but up to the bottom piece and at the same level away from the frame!
And, er, bob your uncle! lol
Oh incase your wondering i used some windscreen bond to stick em to the frame, didnt want to use anything this strong, but in the end I had to, there aint no way theyd be coming off in one piece! lol
Hope this helps!
Re: Frame covers
Beautiful bike mate :thumbup:
Re: Frame covers
Nora, I only spotted the extra bolt above the shock reservoir and then tried to work out what was going on. Is very subtle as I didn't look at the side profile of the bike and think there was anything different when I looked at your 1st picture. :thumbup:
Re: Frame covers
Are those stock CCT's you're running fella?
nora2004
Re: Frame covers
Post by nora2004 »
Kev L wrote:Are those stock CCT's you're running fella?
Knew someone would notice! Lol
They are indeed and tbf have been on for the last 4k miles with no troubles, however I treat them as a yearly item, there due for a change in August!
Its like Russian roulette! Lol
Re: Frame covers
Interesting gambit there mate. Why not just do the stopper mod and save yourself the agg of changing them until they ping? Everyone to their own fella it's your bike and all that. :thumbup: :thumbup:
Re: Frame covers
micks frame covers arrived at mine today, the packing was a shambles :eek2 , how it got here undamaged is beyond me. they look ok, but against my originals, you can tell the quality's no as good. still worth the money imho.
time to repack and resend..... :thumbup:
seb421
Re: Frame covers
Post by seb421 »
Kev L wrote:Interesting gambit there mate. Why not just do the stopper mod and save yourself the agg of changing them until they ping? Everyone to their own fella it's your bike and all that. :thumbup: :thumbup:
+1 to much to risk them going ping
Re: Frame covers
I was thinking about getting these frame covers but with the pore fit I think I will leave it :-(
