bigtwinthing wrote:
Bloody hell you must be some rider if you can feel about 5mm longer on the wheelbase!!! and if your bike only makes power at 7000, i would take it back, lighening the flywheel will lose engine braking, which twins are meant to have. Are you sure you have not got a V Twin with 4 cylinders?
regards Paul.
Well Paul I am not really sure how to take your response so I will answer your questions and statements even though I do find your attitude a bit crusty.....
Yes I can feel the difference with the wheel base change. The front end "feels" more planted to me.
Now I do have to ask about people saying the have better "turn in" when shortening the wheel base with a 43T rear sprocket.
Isn't that "feeling" the 5mm difference in wheelbase? or are they just special also??
Can you please show me where I said my bike only makes power above 7K RPM?
I said maybe you should try running the bike there sometime if you believe you are low on power....... not because it has 4 cylinders but because you would at least be close to he HP & Torque peaks.
In case you don't have the numbers or a dyno sheet the peak torque is in the 7,800 RPM range and peak HP is around 8,700 RPM so it is quite simple....if you want max performance these are the speeds you need to spin the engine.
Many people I have encountered don't know what kind of power these bikes really make as they never rev the engine.
So go ahead and ride the poor thing like a tractor if you like but to really get performance from this engine you need to keep it between 7-9K as that is where the real power lives on just about any VTR.
As for engine braking, you are dead wrong. As stated in an earlier post, a lightened flywheel will give you increased engine braking as just as it is easier to spin up it is also easier for it to slow down.....simple physics.
