Harris rearsets
chric
Re: Harris rearsets
Post by chric »
Jamoi wrote:To low? You should be able to adjust the angle of the dangle on the levers.
Sent from my GT-19505 using Telekinesis
Ill have a gander think my high levels may be in way though
Re: Harris rearsets
Hey Chric, did you manage to adjust your lever in the end?
I've just been looking through the Moriwaki bible, god they made some sexy parts! :thumbup:
Re: Harris rearsets
Jamoi wrote:Hey Chric, did you manage to adjust your lever in the end?
Yes they do and very hard to find too
chric
Re: Harris rearsets
Post by chric »
no forgot all about it going to have a look in morning as its too low and im relying on the front breaks more than i should.
if i cant ill contact harris like you and see what they say :thumbup:
Re: Harris rearsets
Is it the gear lever adjustment you need Chris. On the Gear rod you have a banjo at both ends with a lock off nut. Unlock the lock off nut and undo the banjo and you can un-thread the banjo either end to extend or shorten the rod and then reconnect, tighten up and lock off the lock nut. Watch out for the reverse threads (anticlockwise to tighten). If your lucky you may get away with just unlocking the lock off nuts and spinning the rod part around to raise or lower the gear lever with no need to disconnect the banjo's.
chric
Re: Harris rearsets
Post by chric »
thanks carl think i may have found the problem somet so simple but pissed me off a little bit :evil:
It will cost about 20p to sort out ill post pictures tomorrow
